I have a set of four banded steel original MGB Rostyle steel wheels surplus to requirements.
They've had an extra 1" added to the outer rim and measurements I've taken suggest an offset of approx +7-8mm.
Would require a little finishing if you're going concours, the hard work of banding has been done, but all four hold air/pressure without inner tubes and look nicely retro without being obvious.
PCD is four stud 4.5" (114.3mm). Three original MGB wheel centres included.
