Hi All,
I'm looking for somewhere in the South London area that would be able to drill at set of discs and mount some new calipers on a MK2 Zephyr struts. Any ideas?
Cheers,
Ben
not advisable, drilled discs tend to crack.
not advisable, drilled discs tend to crack. Does that go for if a PCD is drilled into them as well? The disc faces cracking if drilled I was aware of.
not advisable, drilled discs tend to crack. Does that go for if a PCD is drilled into them as well? The disc faces cracking if drilled I was aware Sorry - I should have been more specific. I was talking about changing the PCD, not drilling holes for venting or anything. I've got a set of large Capri discs that I want to put on my Zephyr so the PCD needs to change. I've found someone now anyway. Cheers.
