GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
Nov 29, 2016 21:00:03 GMT
I've found some ideal 'track' wheels for my Sebring but the centre bore is 73mm and I need 76mm....
Has anyone had a go with a dremel to increase the size? or am I best finding a local machine shop....
Cheers Gav
Dez
Club RR Member Number: 34
Nov 29, 2016 21:03:07 GMT
Can be done pretty accurately with a router.
how accurate is down to how well you set up the tooling but I've had pretty good results using to to machine aluminium so far.
Wilk
Nov 29, 2016 21:47:44 GMT
Find a local engineer who'll do it for cash in hand. It's a quick and easy job as long as the lathe has a large enough centre height
I'd gladly do it but my lathe only has a 9" centre and the gap piece doesn't allow enough width for the depth of a wheel
rude
Nov 29, 2016 21:50:58 GMT
Previous owner of my style 5's used a spoon and a hammer on two rims (failed to include this fact in eBay ad) Shocking to look at the craftsmanship. Work ok with inserts tho.
1986 Haunted BMW E24 635CSi 1999 Povo spec BMW E36 1.8i Touring Work Hack 2001 Petrol annihilating Discovery V8 2000 Jaguar S Type 3.0 V6 ~NEW~
