mk2t
Kinda New
Oct 30, 2016 12:27:23 GMT
So the time is coming for me to get my first car and I've been looking at some options and decided I'd like a volvo 340, just as a daily driver and maybe to do a bit of drifting here and there. Although I'm not 100% sure about getting one because I've read that they can be pretty unreliable and also that they're prone to breaking propshafts and stuff.
Anyway, I'm sure a few people on here will have owned one or own one currently so any advice is appreciated. Thanks in advance.
GT4ME
Oct 30, 2016 12:33:15 GMT
Last Edit: Oct 30, 2016 12:49:45 GMT by GT4ME
Oct 30, 2016 12:33:26 GMT
Had a 360, loved it
Oct 30, 2016 17:09:14 GMT
I had one when it was 3 years old and token mileage. It was run up to just under 100,000 miles and other than carb top screws keep coming loose was relatively trouble free. Mine was a 2 door 1.4GL.
Oct 30, 2016 18:27:43 GMT
I had a 360 GLT. Was absolute garbage.
Oct 30, 2016 18:57:49 GMT
I ran this F reg 1.4DL as a daily for 12 months, and even though it didn't set my world alight, it proved to be fairly comfortable and never once let me down. Inside was really basic, with keep fit windows and a tape player, but I love all that simplicity in a car. The only rot I had to deal with when I first got it was the battery tray and O/S/F inner wheel arch. Even the arch lips were all solid. Having the spare in the engine bay still tickles me ! All things considered, I enjoyed my year or so with it, especially in the snow as with the trans-axle and low power it was a doddle to slide about. I doubt I'd have another, although one with a 480 turbo lump in it would be rather tempting
Oct 30, 2016 19:02:55 GMT
i had this 340 earlier in the year, could'nt get on with it.
Chrisâ„¢
This is clearly filler material.
Oct 30, 2016 21:33:50 GMT
I like mine It's never let me down yet, used to be my daily but now more of a toy. Parked it up for 8 months at one point and it just started right up. It's the most reliable car I've owned and I have a Lexus LS400. Propshafts, I guess it depends how hard you abuse it... haven't heard of many people busting the props on standard engines unless they're being aggressive. Mine was my first car on the road and I thought it was ideal: RWD fun but not enough power to really endanger your life. They're pretty awful on fuel if that matters much to you? Don't expect to have lots of choices when it comes to mods either. Limited aftermarket bits are available, otherwise expect to be making stuff yourself or fettling parts from other makes / models.
Last Edit: Oct 30, 2016 21:41:46 GMT by Chrisâ„¢
1989 Volvo 340 1986 Suzuki SJ413 2000 BMW 318ti 2006 Lexus IS250
mk2t
Kinda New
Oct 31, 2016 18:15:43 GMT
That was the kind of of response I was hoping for Chris! You're 340 looks really nice on those wheels, is it the saloon version?
Oct 31, 2016 19:42:30 GMT
I got through lots (20?) 340s many years ago. The mechanical fuel pumps were very fragile (about half the cars I got were non runners - all easily fixed with a new pump) Check MPG, they seemed thirsty but without the performance to make it worth the cost. Otherwise ok, RWD, but I never found them "fun" Also had a 360 very briefly, that seems to have much better power but I've no idea about mpg etc.
I bought a 1988 F reg in 1996 with 120,000 miles. It was the 340 GLE 1.7 with the Renault engine. It wasn't reliable.
It suffered from damp, with moisture getting into the distributor in cold weather and would often be difficult to start.
If you wound it up beyond 80 mpg for too long the car would begin to buckaroo and splutter. I think this was to do with the Solex carburetor warping on the flange and letting extra air in.
Slam the door too hard and you'd hear rust drop inside the door.
It liked to drift. The problem was that it would happen unexpectedly. I nearly lost the back end a couple of times, but then I wasn't wealthy and bought cheap tyres, which were ditch finders.
MPG wise I struggled to get above 35mpg, and though it was a bigger engined variant than the 1.4, it was still to heavy, and overtaking anything needed a long range traffic forecast.
Being a GLE it had electric windows, powered by huge power switches in the centre console. The chairs were comfy, and quite high, more like a living room chair than a car seat.
After buying it for 1,000 quid and putting up with its faults for three years, I part exchanged it for a G reg Audi 80 1.8E and got 400 quid for it, so it was cheap motoring depreciation wise.
I much preferred the Audi 80 - far more solid, quicker and 40 mpg was doable on long motorway runs, with the injected engine. The Volvo felt quite agricultural in comparison, and a bit ancient. Just look at the leaf springs at the back and be awed by the sophistication!
I bought one about a month ago, really like the simplicity of it I've bought an MX5 as my first car (and still have it), the contrast between the two of them is quite big. The Volvo certainly feels older (leaf springs vs coilovers, carbed vs injection,...), they are less fun to drift (private property, Mister Officer...), but it is so comfy in comparison with the Mazda and they are a bit rarer. Would I prefer it over my MX5? I guess not, but they are both great choices for a first car.
johne
I had a 360 back in the day - the carb fed volvo OHC engine 2.0 litre.
Before I got it it had a an engine rebuild due to cambelt failure - but I guess that could happen in any car.
It was comfy - in those days rear wheel drive was much more common so it wasn't unusual.
They were big sellers back in the day - rivalling Escorts and Festers some years in the best seller charts.
The one I had was reliable - the only faults were not due to the car (If you see what I mean) - a lump on a tyre that induced a wobble at 75 mph and the indicators packed in every time it rained which I traced to the aftermarket towbar electrics socket filling up with water and shorting out, blowing the fuse - solved by disconnecting as I didn't need it.
Propshafts run faster than most vehicles of course due to rear mounted gearbox - only shared with exotica like Porkers (924/944?) and the original Alfa GTV (not the later sports car).
I didn't do any drifting heroics or anything - the steering doesn't have much feel and the suspension's soft - it's set up for understeer despite being RWD.
The 1.4s and 1.7 are Renault engines, later ones use Renix ignition.
Last Edit: Nov 2, 2016 16:17:00 GMT by johne
My grandfather had a couple of 1.4s back in the day,i used them quite a lot taking the grandparents out on day trips.Pleasant enough,solid feeling and comfy if a bit dull.The gearlever/shift warning light that used to flash up if you tried anything more than moderate acceleration through the gears bugged me though!
Bracey
The Volvo 340 is one car I never had any desire to own.
But so is the Volvo 940, until earlier this year, then I suddenly just had to have a 940 diesel.
I think its the Renaultness of the 340 that put me off. But as mentioned above, a bit of tweaking could transform it into into a fun slidy thing.
Last Edit: Nov 2, 2016 21:47:39 GMT by Bracey
My Dad had a 1990 1.7 340 for years and I drove it from time to time.
It was mostly reliable. Propshaft bonding failed causing lots of rubber smoke and progressive loss of drive and the crank position sensor failed - handily enough whilst on the ramp being MoT'd.
It was rather slow.
Handling was actually pretty neutral and quite fun to chuck around - but only when no passengers as the amount of body-roll would either freak them out or make them puke...... This could no doubt be sorted.
A good friend had a 360GLT which was a much faster and better handling car if rather thirsty (he has a heavy boot though). He was eventually moved to sell it because it wasn't fast enough to out-drag my much modded 1300 Herald. The Herald did have about 100bhp though and weighed alot less.
Nick
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
Had a few and like you, were some of my first cars. Don't get any ideas that they'll be any good for drifting. Much better as fast B road/rally cars but you'll need to mess around with engine mods or engine swaps to get any decent power. They react well to stiffer shocks and sports springs/lowering blocks.
To put it simply, they're a nice quirky first car to have that'll teach you how to fix things yourself. A little bit like a swedish RWD metro. But if you seriously want to give drifting a go with the occasional skid day? Speaking as a drifter, E36 compact or MX5. Even the 1.6! Damn sight better than the 340s. If you want to do the funny Volvo drift car thing, hold out until you can insure a 940 Turbo.
I have two.
A 340 hatchback I use for drifting and a 360 injection saloon I use daily.
I love them. Easy to maintain, reliable (particularly 360), rear wheel drive, comfy (heated seats), fantastic heaters and look great too.
My only beef with them is the fuel economy. The 360 will struggle to do above 30mpg and the 1.7 340 isn't much better at about 35mpg.
1966 MK1 Cortina 1971 Hillman Super Imp 1985 Volvo 360 GLEi 1986 Volvo 340 1.7 1990 Mercedes 190e 2.0 1993 Peugeot 205 STDT
FOAD
The only drifting you'll be doing is drifting off to sleep zzzz...
1981 Vauxhall Chevette 1984 Mercedes S123 230TE 1988 Peugeot 305 GR 1988 Hyundai Stellar 1992 Subaru MV BRAT 1992 Peugeot 205 D-turbo 2004 Ford Ranger retroshite.wordpress.com/
