lord13
Hi all, I Have just taken delivery of my new project, a Model Y of '36 vintage It is in a bad way, but it is 80 years old so not surprising really, It is a bit out of my 'comfort zone' but the wife and i decided to get one to restore/mod etc after we were give a load of old photos from a family member, in one of them it shows my wife's great great grandmother and her daughter posing in front of their new car, a model Y. Here is the pic... and here is our project... as you can see...there's a bit to do ...
Last Edit: Oct 14, 2016 10:51:53 GMT by lord13
gess
Wow, you really are missing a few bits and pieces here. But I guess you knew that already :-) This will be an interressting build. Are you going to keep it original, hot rod or slightly modified as in modern brakes, engine etc.
Are you going to keep it original, hot rod or slightly modified as in modern brakes, engine etc. Whatever he does, it's bookmarked!
lord13
Oct 14, 2016 11:00:47 GMT
yep there's a lot missing, but i do have all the fenders and the engine cowling, plus the front grill. Also a few boxes and bags of stuff came with it, i have to root through all that lot and make a list of whats there and not there. Plans are a bit of 'modernising' to start with, hydraulic brakes, better springs and shocks, better engine and 'box, but try to keep it looking original i think... maybe . First things first though, i need to get it all stripped down and into my workshop for some serious body and chassis repair
sridgett
the only way is Dagenham
Oct 14, 2016 11:18:41 GMT
Very nice mate, could you not use the running gear from a Sierra or something to make it useable every day?
Mk3 capri, escort xr3i, mk2 fiesta,mk5 escort rs2000
lord13
Oct 14, 2016 11:29:02 GMT
lord13
Oct 14, 2016 11:38:47 GMT
sridgett sierra running gear wont do as it uses mcphereson struts and there will be no where to mount them, no wings etc, i'm looking at either a) viva dampers or coil-overs to replace the lever arm dampers, b) a viva HA clip or something similar, or c) fabricating my own double wish bone / coil-overs set up. something like that anyway, but chassis repair is first task, then i will see what its going to take to alter the suspension, wether its chassis mods to fit a clip, or brackets/mounting points to fit coil overs and keep the existing set up more or less. It's a big learning curve for me, it's gonna be hard...but fun
Oct 14, 2016 12:01:00 GMT
Nice,a tuned sidevalve with Aquaplane stuff would be pretty cool in there.
Love that first pic btw,got a bit of gangsters moll vibe to it !
Rich
Club RR Member Number: 160
1936 Ford Model YRich
@foxmcintyre
Club Retro Rides Member 160
Oct 14, 2016 12:06:34 GMT
MX5 may fit the bill with the suspension, plus a nice drivetrain package to boot. The ideal donor?
richrolls
Club RR Member Number: 38
1936 Ford Model Yrichrolls
@richrolls
Club Retro Rides Member 38
Oct 14, 2016 13:07:24 GMT
Bookmarked. Nice. Looks like it's had a bit of 60's-70's modding in the past going on the gauges fitted. As Rich said, MX5 would be a good start. There's a Morris on here using MX5 bits.
Oct 14, 2016 18:28:32 GMT
heres mine mate if you want a simple build a 100e engine fits. they are very narrow cars. you wont get much in the engine bay with original steering box
Oct 14, 2016 18:29:10 GMT
Nice project!
Oct 14, 2016 18:30:06 GMT
heres mine mate if you want a simple build a 100e engine fits. they are very narrow cars. you wont get much in the engine bay with original steering box Have you a build thread anywhere?
Oct 14, 2016 18:32:51 GMT
heres mine mate if you want a simple build a 100e engine fits. they are very narrow cars. you wont get much in the engine bay with original steering box Have you a build thread anywhere? I didn't build it mate It was done in 2012 from what I now. I just used it for abit of fun why I was doing my project.
lord13
all good suggestions, i'll look into the mx5 route, sounds interesting. chambers1984 that looks great, kinda the look i'll be aiming for i think, 100e engine you say hmmm i will investigate richrolls i'll hunt out that minor, like to have a look at how they did that lots of good ideas people
lord13
small update, due to trouble with registering the old girl and not finding a way around the DVLA rules as yet, the restoration will go ahead 'un-modified' ...well for the most part, there are a few things i can do to the chassis, telescopic dampers, panhard rods etc... Anyway, the strip down commences.... body off Then all the running gear off There are a few areas of concern... Looks like i will have to replace both rails completely, at least the crossmembers are good. The front section of the rails are in pretty good nick, I'm guessing the reason that area was painted was because they were easy to get to, added to the fact that they were probably liberally coated in oil/grease during the cars life as being part of the engine bay. The section of the rails that were under the body were less accessible and not looked after so well, the body itself was like lace on the bottom half, mixed with inch thick filler i knew it was bad but most of it was held together with crud and rust, the actual floorpan was in a terrible state, i didn't have to cut any of that really, i just pulled it off. I didn't take any pictures at the time, I will post some up when i come to renovate them, so you have some before and after shots. So now it is in bits and stored neatly round the back of my house ( so neighbours cant complain about the heap of rust on the drive ) and work will commence shortly on the chassis, I will have to search up a steel suppliers in my area that will supply good 'C' section for the rails as i guess no one out there produces new rails for the 'Y'. I'll let you know how I get on, hopefully i'll get some more done before Christmas
Oct 29, 2016 13:34:33 GMT
transverse leaves, A arms, torque tube, would it need panhard rod ?
or are you redesigning the suspension as a whole?
logicaluk
Oct 29, 2016 17:55:52 GMT
Wow thats not a lot of chassi even before the tin worm took hold, i think your alowed to close channel chassis (to make box section) and still retain full points under the 8 or 16 point system. Dan
Oct 29, 2016 18:22:49 GMT
Brave Brave Brave !!
lord13
darrenh The suspension is staying pretty much the layout i've got due to rules in restoring, but panhard rods can be used, as can telescopic dampers. I'm looking into using coilovers, if they are allowed, if not de-cambered transverse leaf springs will be the way to go logicaluk I'll look into the regs regarding boxing the chassis,it would make it a good deal stronger as you are right the original chassis is weak without the rot. I have to make a jig first to keep it all in line and true, this is going to be a long slow job. grizz a lot of people are saying that! It's gonna take some time, I doubt i'll be coming to the RR Gathering 2017 in it
