Sept 17, 2016 10:27:02 GMT
I monitored a well known auction site and this lad popped up in a local garage, traded in and unwanted. I wanted something cheap and reliable and easy to poke about! A couple of hundred quid later I drove him home! The outside is pretty horrible but the inside is very clean and it has only travelled 44K miles. Plus it has 9 months MOT. After a serious clean it started to look much better. As a treat to myself I tinted the rear lights red and removed the Micra badge. It took ages, very sticky. The lovely 'celebration' will come off. Etc. Rubbed some oil into the black trim and it recovered nicely. Given the dents down all one side I WAS going to rattle can it battleship grey or something but now I think not. Going to sort the panels and do some other bits and bobs. Right the drag and drop doesn't work very well. Starting to look a bit better now!
Currently: 1974 Beetle - Golf -
Previously: e38 735i, e34 525iSE, 1972 Beetle, 1991 Scirocco Scala, Morris Minor, 1983 Polo Breadvan, 1991 Mazda MX6
markbognor
Club RR Member Number: 56
1999 Nissan Micra K11markbognor
@markbognor
Club Retro Rides Member 56
Sept 17, 2016 11:17:00 GMT
Shame the n/s is such a state. Good luck with it.
Sept 17, 2016 15:37:31 GMT
Shame the n/s is such a state. Good luck with it. Ah it won't be a problem. Cheers!
Davey
Resident Tyre Nerd.
Sept 17, 2016 21:16:29 GMT
Get the rub strips off! If you have any questions fire away, have a few how to's on the Micra forum, painted headlight reflectors being one! Corsa b coilovers are a win as you can use the whole front setup and use the rear shocks as they are shorter.
Be aware of the back axle shifting over if you do lower it.
Love these cars, get cracking.
Sept 18, 2016 10:09:22 GMT
Get the rub strips off! If you have any questions fire away, have a few how to's on the Micra forum, painted headlight reflectors being one! Corsa b coilovers are a win as you can use the whole front setup and use the rear shocks as they are shorter. Be aware of the back axle shifting over if you do lower it. Love these cars, get cracking. Yarp the rub strips are coming off v shortly, much prefer a cleaner look. Going to think about the L word. So many speed bumps where I live in prob just need a moderate drop.
markbognor
@markbognor
Sept 18, 2016 19:15:56 GMT
Get it lowered and drive the long way round.
The wheelbase is so short that even if it has to drag itself over the worst speedbumps it will still get over. The only place I ever grounded mine was into a parking field on wet grass.
Sept 19, 2016 16:15:31 GMT
Get it lowered and drive the long way round. The wheelbase is so short that even if it has to drag itself over the worst speedbumps it will still get over. The only place I ever grounded mine was into a parking field on wet grass. Having looked at your thread I think you're a very useful person to know when it comes to Micra goodness!
Davey
Resident Tyre Nerd.
Sept 19, 2016 19:07:05 GMT
Also take note that the lowest part on these is a chuffing great steel cross member that sits below the sump so far less need to worry, that said I did rub through the cross member on mine, it is only bolt on if I remember.
markbognor
@markbognor
Sept 19, 2016 20:39:20 GMT
Also take note that the lowest part on these is a chuffing great steel cross member that sits below the sump so far less need to worry, that said I did rub through the cross member on mine, it is only bolt on if I remember. Yeah, that and the lower front suspension arm mounts - they do have a attendance to wear through.
Davey
Resident Tyre Nerd.
Sept 20, 2016 8:59:47 GMT
I like to call it self clearancing.
Sept 20, 2016 10:55:25 GMT
I'm taking notes chaps.
Davey
Resident Tyre Nerd.
Sept 20, 2016 14:13:30 GMT
How much do you want to know I've had three off these things.
Sept 22, 2016 12:40:24 GMT
Neither of the windows wind up or down farther than a small crack. So this lunchtime I thought I'd investigate further. Wound the window and WHOOSH the entire window drops down into the door. Clouds are gathering overhead. Whip the door panel off and wrangle the pane back up and tape it. A tip remembered from Wheeler Dealers! A bit of examination reveals that one of the plastic window grips has snapped so I'm hoping I can cobble one together. Not sure if such a small component of the window mech can be sourced. I'm suspecting the exact same problem with the other door.
Sept 22, 2016 15:05:17 GMT
Pulled off the horrible trim. It was damn sticky but rewarding. I bought some GOO GONE which is OK it's made out of petrol and lemons I think but I think I need some standard unleaded to get the gunk off. Just glad it is round the edges not covering the entire back surface of the trim. The Wrong side. www.imageupload.co.uk/images/2016/09/22/IMG_3661.jpg
Davey
Resident Tyre Nerd.
Sept 22, 2016 15:12:30 GMT
I had that exact problem with my drivers window, I got some windscreen adhesive and glued the window back in the plastic clip thing, lasted until I killed the car.
Sept 22, 2016 15:22:51 GMT
I had that exact problem with my drivers window, I got some windscreen adhesive and glued the window back in the plastic clip thing, lasted until I killed the car. Yep I'm thinking strong glue is going to feature heavily in this repair.
Sept 22, 2016 18:32:24 GMT
Removed the rear wiper and bunged the hole. 'Celebration' decal just peeled off EZ PZ, wish all the trim was that easy. post image
markbognor
@markbognor
Sept 22, 2016 21:13:53 GMT
Got an early (no badge) rear numberpalte light down here, and a pair of pop out windows if you fancy diving down to the south coast with a box of bulmers.
Sept 22, 2016 22:02:31 GMT
Got an early (no badge) rear numberpalte light down here, and a pair of pop out windows if you fancy diving down to the south coast with a box of bulmers. That's a very kind offer Sir, thank ye kindly. I'll be in touch when a free weekend presents itself. Many thanks!
Sept 23, 2016 9:48:38 GMT
Dirty, dirty boy.
