Sept 13, 2016 22:02:34 GMT
also have a set of 38mm chokes. (modified from 36mm) £30 delivered
luckygti
I need to try harder!
Might be a dumb question but will these fit 40's?
luckygti
Cool, thanks.
sidewaysbo
tryed the rest back to v8 s as there the best
Nov 22, 2016 21:28:36 GMT
bozwell you say tea strainer ram pipes id 48mm but are the stud hole wide enough to fit my 2 x 48 dcoes i don't want to replace mine with these if these would restrict air intake amount atall feller
mk1 escort 4.6 v8 rover tryed the all steel 4 pots & turbos but always go back to my v8s making music
i have no idea so the safe thing to say would be no.
sidewaysbo
Nov 24, 2016 22:37:33 GMT
could you measure diametre of both two intake holes each end of a ram pipe .and and distance between mounting hole studs please thanks bo
sidewaysbo
Nov 24, 2016 22:38:45 GMT
ps forgot to say its alloy rampipes with tea strainers on i am interested in. could you measure diametre of both two intake holes each end of a ram pipe .and and distance between mounting hole studs please thanks bo
Nov 25, 2016 19:02:47 GMT
65mm
Nov 25, 2016 21:14:36 GMT
Where in East Sussex are you? I'll be back home tomorrow in Brighton. Interested in the parts. Thanks.
Nov 25, 2016 21:18:33 GMT
Slightly OT, but who modified your 36mm chokes for you? I have a set of 38s, but need 39s. But 39 is an odd size so impossible to find. Didnt realise they could be modified. Would be great to find someone who could make 39s out of my 38s
Don't Fool with the OLD Skool
Nov 25, 2016 23:11:03 GMT
i'm in Bexhill-on-Sea.
any machine shop should be able to turn the chokes but they aren't a straight bore but a taper so it takes a little working out. I could turn them on my lathe if I have a few spare hours to set up the machine and make a cutting tool to get the correct profile of the cutting bit to machine the curve.
sidewaysbo
Nov 25, 2016 23:25:01 GMT
is that distance 65mm is between studs i take it .and as i mentioned i need hole size measurement in each end of a rampipe outer side and carb side cheers bo
Last Edit: Nov 25, 2016 23:32:16 GMT by sidewaysbo
