Sept 13, 2016 20:00:09 GMT
Audi A8 Sport wheels x 68Jx18 ET48 5x112 Center Bore: 57.1 mm Fit various Audis, VWs and VW vans1 x with Bridgestone 245/40 tyre (approx 5mm tread) wheel in very good condition. 4 x with budget 245/40 tyres. Loads of tread (6mm +) but not great tyres. Three of the wheels are average to good, one has a dink in the rim but holds air and drives ok. 1 x with no tyre. Looks average to good, but has had a small weld repair. No centres. Located nr South Petherton in Somerset 1 mile from the A303 and about 15 mins from Haynes motor museum. Collection much preferred as they add up to a big, heavy pile! £ 200 ono PM on here or 07909 490294
Sept 18, 2016 20:42:23 GMT
Bump....
Oct 27, 2016 15:59:56 GMT
Bump.....
nick(at)tengaston(dot)plus(dot)com
Could be interested. Any close up pictures available?
Nov 11, 2016 10:28:49 GMT
Wheel 1 Very good this one - looks to have the been spare for a long time. Factory finish still in good condition. Has Bridgestone tyre. This is worth a fair chunk of the whole price on it's own. Wheel 2 Has been refinished at some point and is a bit tatty but no major dinks Wheel 3 As wheel 2 but with small dink nr 12 o clock Wheel 4 As wheel 2 Wheel 5 As above but does have a significant dink as pictured Wheel 6 No tyre. Somewhat tatty but no major dinks on the front face. It has had a weld repair on the rear lip which looks nicely done. Looking at these again makes me realise that some (most even!) are better than the ones on the car and I ought to mix and match - different size tyres on the car mean this is not a minor job though......... Nick
Last Edit: Nov 11, 2016 10:33:51 GMT by vitesseefi
Do you think these would fit on my audi 80?
Dec 16, 2016 17:14:59 GMT
Pretty sure your 80 will have 4 x 108 pcd and also these will just be plain too big. Did try them on my C4 A6 (which does have the correct pcd) and they are too big for that. Would probably just about drive in a straight line but no room left in front arches for anything technical like turning corners. Looked a bit like a donk also.
Nick
Yep.
Bump......
Mar 25, 2017 20:43:38 GMT
Still available. Open to sensible offers.....
Nick
