Jul 26, 2016 12:51:03 GMT
Is this a good idea to save on a couple of hundred pounds? Bearing in mind the genuine BMW turbos failed miserably (but after about 70,000 miles) - not sure if this was down to poor servicing. They seem to range between £199 - £300, are these recon (like the ones you can get in this country), or newly manufactured? I'd be more suspect of the newly manufactured ones. Has anyone had one go? Why are they so bad (casting? etc)
Jul 26, 2016 15:17:25 GMT
A friend bought 2 for his compound charged MGF as he expected to kill one before getting it right and the first one died due to lubrication issues (due to the set up not the turbo itself) the 2nd is still ok once the lubrication system has been sorted. I can find out who/ what website he got them from if you want.
sb
Jul 26, 2016 18:18:41 GMT
Look up bone marrow by hot rod garage, they built a twin turbo big block with cheap Chinese turbos and had no issues
Jul 26, 2016 18:21:58 GMT
Lots of people buy them, then rebuild them straight away with genuine bearings.
hario
S202 C300STD
Lots of people buy them, then rebuild them straight away with genuine bearings. I can tell you from experience on the Chinese Holset clones a genuine Holset bearing rebuild kit fits
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
Adey
Club RR Member Number: 171
Buying a Chinese turboAdey
@adey1984
Club Retro Rides Member 171
Lots of people buy them, then rebuild them straight away with genuine bearings. I have a pair of used and working fine Chinese ko4's for my audi b5 s4. I plan to do the same before fitting them. plenty of people in the states who build hybrids do this and a fair few uk folk are starting to do the same. the issue comes with finding a company willing to do it as some wont work with non genuine parts
Aug 12, 2016 11:35:25 GMT
Personally I have no experience, but have heard things about poor bearings, poor quality castings etc. For the sake of a few hundred quid, just buy a proper holset/BorgWarner/schwitzer. They are very cheap for what they are (more than half the price of the equivalent garrett etc) you just need to know where to look. Cheap, genuine borgs can be had from tractor autoparts. Tuners put massive markups on them, e.g. S300 turbo I have seen for up to about a grand, but you can get them for less than half that new.
By the time you buy a Chinese turbo, replace the bearings, you've saved literally a few quid. SOME people MAY have had success with them, but there isn't much come back/guarantee if it does go wrong. Not worth it.
Last Edit: Aug 12, 2016 11:36:21 GMT by chodjinn
tim124
Aug 21, 2016 16:58:02 GMT
I've used them several times, at the moment I have a GT27R copy (plain bearings) been on my bike 40K+ miles at up to 26psi still running sweet.....
Aug 21, 2016 19:33:46 GMT
I see lots of horrible cheap copy stuff all the time, almost always in for rebuild after premature failure. I wouldn't touch it myself.
Paul Y
The general opinion from the American forums is that they are a lot better than they used to be. A disassemble, clean (to remove the casting/machining residue) and careful reassembly seems to cure most faults. One3 have got a good reputation with the LS and Mustang crowd. I am going to use one on my truck when I finally can spend some time/money on it! P.
Aug 22, 2016 11:52:54 GMT
I use two on my Volvo, the general issue with them seems to be too high oil pressure because they don't come with a restrictor, I used a pop rivet in my first Chinese turbo without any issues and the turbo has gone through two owners since and is still fine four years later.
Feb 16, 2017 10:06:24 GMT
6 months later and about 10,000 miles later the Chinese turbo is still running OK. The original turbo was fine, the oil pressure circulation filter was clogged solid and forcing oil out through the seals. Ah well.
fad
Feb 16, 2017 10:17:22 GMT
Chinese turbos used to be like a Chinese meal... Satisfying at first but you find yourself needing another one shortly afterwards.
The historical reason for the price difference is also the metal used in the castings. Your detonated BMW turbo there held all the bits inside when it went. The trouble is, the material used in the cheaper castings is not designed to contain a turbo burst, and so *IF* your turbo grenades, that is where you will "feel" the price difference. In terms of functionality etc they are likely pretty much identical.
This is an (old) video of a turbo burst being contained. It's why turbo housings seem expensive for what they are when you buy genuine ones.
Here is a video of a direct comparison between a genuine and copy turbo:
I have NO recent experience of Chinese turbos. I'm using a genuine garret T3 on my Volksrod running carbon shaft seals, I'm proper old skool LOL
Last Edit: Feb 16, 2017 10:18:30 GMT by fad
Feb 20, 2017 11:42:59 GMT
The original turbo didn't detonate, there was nothing wrong with it apart from maybe seals needing replacing. The new turbo was £250, I did check on a genuine one from BMW Chester but it was just too expensive, I bought everything else from there amounting to just under £300.
fad
Feb 20, 2017 12:09:06 GMT
Why the shattered compressor wheel then?
Rich
Club RR Member Number: 160
Buying a Chinese turboRich
@foxmcintyre
Club Retro Rides Member 160
Feb 20, 2017 13:39:26 GMT
Why the shattered compressor wheel then? I get the feeling that they were photos to keep the thread interesting We only use CHRA turbo cores at work and my tweaked 300TDi landrover is running one with no ongoing issue, original turbo failed on mileage (248000!) and previous experience with CHRA units proved good enough to warrant it. Means keeping the OE castings, so safety-wise, ace, and I've not had one fail, whereas I have had 'cheap' UK sourced complete turbochargers fail quite alarmingly quickly.
Feb 20, 2017 14:42:08 GMT
Why the shattered compressor wheel then? Sorry, they were just reference pics for Chinese turbo failures.
fad
Feb 21, 2017 19:25:39 GMT
Aahh I see.
Keep in mind these thing spin fast. F*cking fast. Any imbalance, imperfection etc is game over.
I used to work for Borg Warner machining and balancing compressor wheels. Tolerances were SO tight. About 15% of wheels were scrapped owed to tiny casting blemishes, imbalances etc that could not be machined out. Crazy tolerances!
Feb 21, 2017 19:55:16 GMT
coyote
says it all.
Don`t eat yellow snow!
