Evening,
I have a VDO wideband AFR gauge. It has 4 wires- +12v, Ground, Dimmer (to be wired onto the headlight switch) and a 0-5v sensor input.
My question is, can I make this work with a universal wideband sensor, or do i need some kind of controller?
I'm hoping a Wideband 0-5v sensor will literally just give an output ranging between 0v and 5v depending on running condition, which can be inputted to the gauge.
Thanks in advance
Thanks in advance
