Jun 15, 2016 19:20:29 GMT
Can anyone tell me what sort of front and rear suspension the mk1 espace uses? I/e is it McPherson strut up front, and rear beam with coils and separate shocks? My moderate googling has provided no answers. cheers
scmick
Jun 15, 2016 19:31:28 GMT
My experience is with the Mk 2 models which used basically the same layout. The rear suspension uses a rear beam, coils and separate shockers plus a panhard rod arrangement. At the front, they are not macpherson struts as such, more like coilovers working on the top suspension arm. Down below a lower arm and tie rod assembly forms a triangle. I am scrapping a Mk 2 and still have the rear axle and springs if you need them.
Jun 15, 2016 19:37:24 GMT
fabulous, and thank you for the offer. I don't think i'll need the springs however
