Hey all, My classic motor scooter is battery-less and runs 12v AC. I am currently trying to run panel less and wanted some smaller indicators so it's still road legal and bought some LED ones without thinking about it as you do. I then realised afterwards that I need to somehow convert the power, I know very little about electrics and LED's in general. From what I've googled I need to run a converter something like this: www.superbrightleds.com/moreinfo/battery-and-cps-compact-power-supplies/12v-ac-to-dc-converter-module/1725/I'm completely unsure, especially since they're not going to be on constantly. Other threads on the matter make it seem very complicated with different resistors, Ohm and AMP differences. Is there anyone out there that could dumb it down even further? I can measure different readings of power from the scooter using a meter if equations need to be done, cheers.
If it had indicators in the panels you removed, can you refit just the indicators to the bike without the panels? LEDs won't work with ac power (unless you convert it to dc with a black box , rectifier etc) Old-school bulbs work fine with ac power
May 12, 2016 17:38:58 GMT
Just take them off and tape over the switch, problem solved. They aren't required anyway
May 12, 2016 18:46:40 GMT
Just take them off and tape over the switch, problem solved. They aren't required anyway Since the scoot is a 1980 model I think that may actually be an option according to www.legislation.gov.uk/uksi/1989/1796/schedule/7/madeI'll keep looking into rectifiers as I'd prefer to let the good public know where I'm heading With regards to fitting the lights off the panels, there's no way to mount them well unless I cable tie them up somewhere or make brackets which I don't have the means to do and it would look like a proper hack job compared to the slick billet ones I have =)
May 12, 2016 20:07:49 GMT
I've never actually had working indicators fitted to anything other than my rd125lc I took my test on and my cb900, I always took them off everything else. Arm signals, Forcefully riding/ road positioning and if all else fails a boot into a door panel has always surficed. (Although I wouldn't recommend that if you don't have a clear means if exit)
May 12, 2016 22:02:11 GMT
When I took my test, in 1974, even if you had indicators (my bike didn't) you had to use arm signals.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
I seem to remember covering this at tech. A simple rectifier circuit can be built with 4 diodes. Something like this;
May 14, 2016 12:08:07 GMT
I seem to remember covering this at tech. A simple rectifier circuit can be built with 4 diodes. Something like this; That is a Wheatstone Bridge and the diodes are encapsulated in the little silver box shown in my earlier post.
MrSpeedy
East Midlands
May 14, 2016 16:31:28 GMT
I seem to remember covering this at tech. A simple rectifier circuit can be built with 4 diodes. Something like this; That is a Wheatstone Bridge and the diodes are encapsulated in the little silver box shown in my earlier post. I couldn't remember what it was called but I did remember what the schematic looked like! lol
Last Edit: May 15, 2016 21:08:33 GMT by MrSpeedy: Spellchecker fail
squonk
May 15, 2016 19:36:02 GMT
That is a Wheatstone Bridge and the diodes are encapsulated in the little silver box shown in my earlier post. Sorry, that's not a Wheatstone bridge. A Wheatstone bridge uses resistors, not diodes ( en.wikipedia.org/wiki/Wheatstone_bridge ). It's a bridge rectifier.
May 15, 2016 20:53:52 GMT
That is a Wheatstone Bridge and the diodes are encapsulated in the little silver box shown in my earlier post. Sorry, that's not a Wheatstone bridge. A Wheatstone bridge uses resistors, not diodes ( en.wikipedia.org/wiki/Wheatstone_bridge ). It's a bridge rectifier. I stand corrected and hold my head in shame about giving wrong information To be fair though it's lucky I remembered anything about it as left school 40+ years ago and haven't thought about it since.
