Looking at dropping the back of my van 2".
I had planned to decamber the spring (single taper leaf).
However, I just looked and the spring is a but flat. Not sure if its sagged?
So, could I add camber to the spring? If they have sagged should I get them re arched and re sprung proffesionaly?
if they are supposed to be like this could I extend the spring mounts and shackles?
If I could raise the van 2" I could then swap the axle to be above the spring (should drop it 4") then ill have my 2" drop.
