Hi All,
I need some assistance with setting up a 32/36 weber on my dads mk3 zodiac.
The setup currently:
Primary Choke
Idle - 45
Main - 140
Air correction - 165
Secondary Choke
Idle - 45
Main - 135
Air correction 140
The idle jets were 50 but i've stepped them down to 45 as it was running too rich on idle. So this is okay now.
On top end when going through gears 3 to 4 it starts to miss a bit so i changed the secondary main jet from 125 to what it is now which is 135 so this has now improved with only a slight miss now, i may also change the air correction jet on the secondary from 140 to maybe 150 to lean it up a bit.
Has anyone had experience of setting these carbs up on zephyrs/zodiacs and what jet sizes were used?
Thanks,
Bhups
Primary Choke
Idle - 45
Main - 140
Secondary Choke
Idle - 45
Main - 135
Air correction 140
Thanks,
Bhups
