first up, a couple of pairs of shelf mount speakers.
set 1- goodmans, later rounder type but with big logos on em. one grille missing (easy to make another from an old door speaker grille as its small), hence £15.
set 2, older proper 80s set, made in japan. fairly good condition, some scratches to casing but overall not bad. cones are starting to fall apart but they still work ok. you can buy cheap uprated small speaker cones from maplins or ebay to replace them though, the value here is in the casings. £30.
honda civic rad. brand new, some storage marks to fins. it fits pretty much all civics, CRVs, etc 1991-2001. its the little one used a lot for engine swaps. £20.
lada riva estate rear door. vgc, no dents or rot. needs paint obviously! complete except door card. £40.
i do have 3 other doors but they all have dents/scrapes although are rustfree. i also have a lot of interior parts, mostly in black.
door cards, rear load area trim, etc.
micra K10 parcel shelf with a pair of pretty much new FLI 6x9s cut in. shelf has a few marks but is presentable, speakers are as new. £25.
i also have a matching pair of round door speakers without grilles for £10.
pretty cool swedish retro aircraft style lap belts. came out of a '60s amazon. webbing is silver/grey and they have weird translucent plastic latches. all complete and pretty good order, some minor rust to chrome on the mounting tabs. £45.
another set of cool belts, this time from a late '60s ford truck. they're metallic blue and chrome, push button release, and are recoil lap belts which is unusual. good condition, just a bit dusty. £50.
box full of 1200 beetle light bits. one casing which needs a small repair, some lenses, lot of trim rings, bulbholders/reflectors and screews. £20 the lot.
pretty nice e30 centre console rear section, with handbrake boot and ashtray. not mint but close, could do with one edge carefully reglueing, but given how gragile these are its not at all bad. £25.
