Ive had a sort through the excessive spares ive got and found that ive got ebough duplicates to last beyond time itself
3.5 4cu flapper parts
1 Complete running efi setup £130
1 Engine loom £25
1 flap air meter (broken flap)£0
1 inlet manfold without plenum top otherwise complete £20
6 injectors fitted to scabby rail £5
Hotwire 14cux parts
1 engine loom £25
1 used flow meter £15
Also
Weber 32 dir £40
weber 32 dgm £40
3.5litre pair of stromberg carburettors £0
K series 16v 36mm bike carb setup manifold,carbs and 38mm air horns £150
Dissassembled and clean G suffix lt77 needs a new input shaft and bearing or ideal for parts £15
SD1 gearchange remote Sold
Unknown origin but half decent twin pipe back box £50
Tiny lightweight alternator £20
Dolomite sprint rear axle complete with disc conversion (excellent working diff) £140
Metro VVC145 conversion parts £200
(engine, pg1 gearbox, MG TF front subframe (subframe now gone),TF manifold and downpipe, engine wiring loom, ECU, immobiliser and fob)
the engine is partially stripped as I was going to fit a new headgasket and timing belt and there is a few parts needed to complete the setup like the gear selector, steering rack mounts, brake discs, car loom for the ecu to plug into etc
also the cylinder head looks much newer than the engine so I suspect its a newish replacement
Renault 5 phase 2 turbo parts £200 the lot :
solex 32dis blow through carburettor, excellent looking condition but missing the choke flap
Phase 2 watercooled turbo looks to be in basically good order but untested and has the actuator missing
Inline bosch fuel pump (unknown condition)
oem Renault boost referenced fuel pressure regulator (unknown condition)
generic intercooler in rough condition
Tools
Wolf single speed drill £20
Black and Decker 2 speed drill £25
Makita single speed 110v drill £10
bench grinder sold
Gunsons multimeter £10
Record Steel engineers vice £50
Record "1ton" cast iron vice £20
pictures are in the thread
All of the parts can be posted, or delivered to a reasonable radius of Chesterfield or even picked up
1 Engine loom £25
Hotwire 14cux parts
1 engine loom £25
Also
Weber 32 dir £40
weber 32 dgm £40
Tools
bench grinder sold
