Apr 11, 2016 20:05:44 GMT
Try this guy I've had parts off him before and everything has been great. He breaks Rover V8's and Range Rovers. He's none listed but I've been in his garage and he has loads of stuff. I know he had an RR efi ecu as I borrowed one to dbl check mine! pages.ebay.com/link/?nav=item.view&id=121946733095&alt=web
"To Big block or not to Big block?" Thats the question!
Apr 12, 2016 18:33:58 GMT
thanks, ideally id like to borrow one as well to double check mine but i will buy one for spare if necessary
87 manta redtop quantum 2+2 1973 mini xe'd mk4 astra van
Apr 12, 2016 18:55:29 GMT
Why do you suspect ecu? I did same and tried 5 different one's. My own ran best. Still got fuelling fault tho. May be worth you starting a thread in technical giving symptoms? A lot of ppl with V8 experience on here.
Apr 14, 2016 12:45:27 GMT
it has good fuel pressure ( new pump and checked ) good spark will run on easy start/brake cleaner will cough as though the cold start injector is working? same symptoms as the last RR i had and this ecu worked on that but not now on this one
Jun 12, 2016 11:30:33 GMT
sorted thanks
