Hi all.
Anyone have any ideas about how I can find a similar idler pulley to the one on my engine? It's not an item that any motor factors carry any more - it's for a cosworth 24v v6.
I've heard that there's a merc one that fits, but my local motor factors' book only lists them by part number, not dimension.
It's a flat pulley, for a 6-ridge belt, so 26mm wide or more, with a 17mm centre bore, and a 70mm outside diameter, although that's not crucial. The centre bearing is 7mm inboard of the outer edge.
Any thoughts would be greatly appreciated
Cheers
Jake
Cheers
Jake
