Specs:
1985 CL in quartz grey metallic 121K miles 5 door can do cuts once all parts are gone
Chrome handles some small dents in a couple and some are quite stiff £40 with keys and ignition switch
All early spec equipment retained: 7 slat grille, quarterlight doors with small rub strips and mirrors, small bumpers and I think boot washer fluid bottle.
1998 ABF circa 185k miles ran well in donor, cam belt done 2012 circa 165k miles. Hasn't ran since start of 2014 due to wiring not being finished on my golf. All wiring included pre cut from previous owner, will plug straight in to a CE2 loom. Comes with flywheel and clutch assembly fitted £250
Mk2 subframe with the correct engine mounts to fit an ABF engine. New wishbones and bushes plus new ARB drop links fitted from VW but they split after doing nothing for two months! Engine mounts are good, £60
Mk2 GTi hubs with vented, grooved and drilled discs (below limit or close to it I think) £60 for the pair
Mk2 GTi gearbox (5 speed 020?) no crunch in to 2nd £50
100mm driveshafts with new CV boot on O/S outer iirc a new CV joint on O/S at gearbox £50
9" brake servo and 22mm master cylinder, rust removed then painted with hammerite, retained original sticker £60
Fully rebuilt GTi rear beam with nearly new solid discs. It was shot blasted, painted with several coats of hammerite, new brake pipe clips and new OEM bushes fitted £80
standard interior, I haven't seen another one on here with this interior! Both front seats dig in to your back. Driver's seat has usual bolster wear. Passenger seat is in VGC just has a small hole. Rear seats look like they have never been sat in. Offers
Small chrome bumpers, faded but I gelled them every couple of months. some rub marks on all four corners, rear bumper in VGC. Front bumper has a small split below drivers headlight and the previous owner was an idiot, obviously took the bumper off and didn't fit it back on properly so to hold it on they screwed it down! The screw holes and split can't be seen once fitted. Offers
7 slat grille with eyebrow spoiler, cracked on drivers headlight and most clips broken, looks good fitted SOLD
7 slat without eyebrow spoiler, no cracks, discoloured patch by passenger headlight, all bottoms securing clips intact all top clips broken. I was going to cut the clips off a debadged grille and plastic weld them on. £70
GTi fuel tank £20
Good condition drivers headlight £15
Passenger headlight has condensation inside £10
All parts are plus postage or collection from Worcester obviously not all parts are listed so let me know what you want.
Still have quite a few 1.3 parts left too including rear beam and HK engine with no ancillaries.
I will add photos once I can access my laptop.
GTi fuel tank £20
