I am about to start working through the rust issues on my van. Everything I can remove will be removed. Bits I cant get at I may as well treat before I seal/paint.
The awkward bits will be mainly seams and hidden corners.
I know treatments are often debated, ive used a few with varying degrees of goodness (some green gell one actualy removed the rust and was quite good but had to be washed off).
What I need though is something fluid so it will creep into seams, and then not cause harm when its dry and sealed in.
Ive read about a few different ones but don't want to end up ordering something that is good, but too thick to creep into the joins.
Any recomendations?
Plan is wire wheel, cut out anything I can and replace, then treat, epoxy prime, then seam seal.
Any recomendations?
