barty
Mar 16, 2016 20:26:38 GMT
Can anyone help, my son has an old toyota touring car it is running on throttle bodies and we cant get it to start, we get a good spark and we have fuel at the fuel rail. Both fuel pumps appear to be working. one is the lift pump from the tank to the swirl pot and the other is the injection pump, we have loosened both lines and get a good flow of fuel but the swirl pot seems to only have a drop of fuel in it, now should the swirl pot be full?? any help would be great thanks
andyborris
Mar 16, 2016 21:07:32 GMT
Yes, the pot should be full, does the excess fuel from the injection rail feed back into the pot?
The lift pump may provide enough fuel to run the run the engine, but the injection system needs more than that, to provide the required pressure for the injectors.
And the swirl pot needs a return to the fuel tank!
barty
Mar 19, 2016 18:13:02 GMT
the car has been running and actually took part in a few races and is well known in the touring car class, as far as i know it was fine till it ran low on fuel. All the filters are clear and the lift pump seems to flow at a good rate as well as the injector pump, all fuel lines are as fitted and not touched since it was built.its just a mystery why the swirl pot does not fill up. i suppose the union from the lift pump into the swirl pot could be blocked ?? or the pump could be breaking down under pressure Thanks for your input
Mar 19, 2016 19:20:40 GMT
definitely start there seeing as its not filling the swirl pot.
barty
Mar 22, 2016 20:02:27 GMT
thanks
hario
S202 C300STD
Apr 20, 2016 15:01:31 GMT
Air lock?
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
barty
Apr 20, 2016 17:11:32 GMT
just a quick update, as its my sons car he managed to get a very knowledgeable man from Hastings who knew a few things about the management system ( motec i think)and it now starts, it seems it needed more bar on the fuel pressure. i hope this has cured it but as he has just had a baby he has not had the time to spend on it and of course as the baby is here it is now up for sale , he wont sell it till it running right
