Feb 19, 2016 15:59:08 GMT
As above, does anyone know how I can find out the reg of a car from just the VIN?
I picked up a cheap car via Copart (It's not cat recorded), but it comes with no documents and no reg plates. I've checked for etching on the windows etc.
Cheers
Mike
Specialist Bodyshop & Fabrication Classic, Retro, Prestige & Custom Small Repairs to Concours Restorations Mechanical Work Vintage to Modern
Feb 19, 2016 19:02:44 GMT
Trade HPI on the VIN/ chassis number. Must be a TRADE one to do it this way.
Feb 19, 2016 23:31:55 GMT
I should be able to get for you. Message me the vin.
Don't you have to be in the trade to buy a car like that from Copart?
Last Edit: Feb 20, 2016 2:04:15 GMT by Deleted
Feb 20, 2016 11:22:09 GMT
if you mean by created an account with copart, means you are trade, guess so.
Feb 20, 2016 11:57:53 GMT
I should be able to get for you. Message me the vin. Do you have access to motorcycle data as well? Got 3 frame numbers I need running, I'm certain 2 are registered at least but the DVLA took 9 weeks to process the last lot I sent off and am sure one that has come back with no record is actually registered but has/ hasn't got the prefix on the frame number.
Feb 20, 2016 20:38:49 GMT
I should be able to get for you. Message me the vin. Do you have access to motorcycle data as well? Got 3 frame numbers I need running, I'm certain 2 are registered at least but the DVLA took 9 weeks to process the last lot I sent off and am sure one that has come back with no record is actually registered but has/ hasn't got the prefix on the frame number. Should be ok, i can but try.
Feb 25, 2016 13:19:36 GMT
Don't you have to be in the trade to buy a car like that from Copart? You need a Copart account, but private individuals can register for an account to buy from them if they so wish.
