For sale are some parts I have been hoarding "just in case": Tilton 74 series brake master cylinder kit plus a couple of extra reservoirs. M/cyl has been used briefly for testing. 3/4" bore. £55 posted Coil over springs 2 1/4" diameter, 7" long, 350lb x4 used. £25 posted PER PAIR Helper springs 2 1/4" diameter, approx 2" long, x4 unknown rate. Also used. £20 posted PER PAIR More to come when I can dig them out
Sittin' here in a hired tuxedo. Wanna see my bacon torpedo?
PhoenixCapri
West Midlands
Club RR Member Number: 91
Do the helper springs come with the adapters to fit between the main and helper springs?
Sorry, no they don't. I only have those bits for now.
hi curryracer can you tell me how many outlets does the master cylinder have
cheers cos
Sorry for late reply.
Looks like two. One in line with the push rod and one vertically, directly above that which has a bleed screw fitted.
Both are AN-3 3/8x24.
Will double check which fittings I have left.
Feb 16, 2016 15:45:54 GMT
Sorry I have no fittings, but they are standard sizes so should be easily available. Any offers? as I am not going to need them, just the space ?
Mar 19, 2016 20:00:05 GMT
Last chance before they go in scrap bin ? ? ?
Mar 19, 2016 22:42:57 GMT
Pm'ed Chris.
"To Big block or not to Big block?" Thats the question!
m1keh
Do you still have the master cylinder and reservoirs?
Mar 22, 2016 19:56:30 GMT
Yep, all parts still here for now.
