Jan 27, 2016 20:32:40 GMT
Hi,made the trip down to Weston S Mare to purchase ian1's omega and drove it the 200 odd miles home at an ave. of 25mpg which was less than I expected. Probably due to the constant misfire.(more of which to follow). First thing to sort were the cam cover gasket oil leaks,which could be the source of misfire due to contamination of the plug leads. Had to remove lots of gubbins to get this far..... which revealed this spark plugs swimming in oil. more to follow when I check the condition of the coil pack.(another common cause of misfire on the V6)
Last Edit: Jan 27, 2016 20:33:22 GMT by zippygte
'97 omega tourer 2.5i '95 omega elite saloon 3.0i '65 a40 farina mk2 '57 a35
Omega Tourer V6Deleted
@Deleted
Jan 27, 2016 21:02:49 GMT
my dads old 2.0 ecotec powered one had that oil round the plugs too.... seems to be common on old Vauxhalls..
Jan 27, 2016 23:00:13 GMT
Good luck accessing the coil pack!!! Sometimes easier to remove the N/S exhaust downpipe, whilst trying to avoid snapping the studs off in the manifold!?! /
Jan 28, 2016 12:11:06 GMT
Yeah! I'd like to meet the git at GM who came up with that location. After much cursing and skinned knuckles got it out without moving the downpipe.As you can see in comparison with a good one it has a couple of large splits in the casing and loads of hard to see hairlines. Luckily in my large stash of omega spares I had another and a spare set of leads. next job put it all back together,lefthand cam cover should be fun.
Last Edit: Jan 28, 2016 16:47:25 GMT by zippygte
good fun, there. the wifes Passat did the same thing with the valve cover gasket letting oil into the plug bores.
JP
Jan 29, 2016 15:19:15 GMT
Fit new rocker covers as the plastic ones warp Or convert to metal Vectra rocker covers or your wasting your time... Been there done that...
Phil H
Club RR Member Number: 133
Omega Tourer V6Phil H
@philhoward
Club Retro Rides Member 133
Jan 29, 2016 16:22:05 GMT
Clear the breather box out on the back of the OS head and the flat plate on the top as well - the word on the street is only used Vauxhall gaskets and sealant otherwise they will leak again (mine do..because I didn't). Also carry a genuine crank sensor in the glovebox.. Apart from that, keep an eye on the coolant - any mayo is probably the oil cooler rather than a head gasket issue. Saying that, if you've had a Vauxhall V6 before, you'll know that already
Last Edit: Jan 29, 2016 16:40:52 GMT by Phil H
Jan 29, 2016 17:05:47 GMT
Yes,well versed in all omega V6 faults,breathers all clear.
Jan 29, 2016 19:22:02 GMT
I do like an Omega wagon, almost to the point of regretting breaking one to power the Scimega.
Jan 29, 2016 19:41:35 GMT
I've got a spare x30xe and gearbox which if I get the time would quite like to put in something retro and rwd,mgb or chevette maybe.
bstardchild
Club RR Member Number: 71
Omega Tourer V6bstardchild
@bstardchild
Club Retro Rides Member 71
Jan 29, 2016 23:46:24 GMT
I do like an Omega wagon, almost to the point of regretting breaking one to power the Scimega. I will continue to applaud you for that - you did the car world a service #notanomegafan #sorryforthenegativepost
We ran a 2.5 Auto Omega Estate for a few years I don't think it ever managed as much as 25mpg!
Poxy electronics and gearbox with inbuilt self distruct spoiled a lovely comfortable car, keep a spare crank sensor handy, from memory we went through 4 in about 3 years, as well as coil packs and a gearbox. Still on the plus side the cam belt is nowhere near as tricky as people would have you believe.
Jan 30, 2016 11:13:37 GMT
Head gaskets on the other hand...
I've done one set. Never again.
Jan 30, 2016 14:57:33 GMT
Not a problem,it'd be boring if we all liked the same.
omegod
Jan 30, 2016 15:25:25 GMT
I remember doing my 3.0 coil pack in -9 conditions , one of the bolts was a complete nightmare and got left out on reassembly. Would consider getting an MV6 if I can find one on gas
bstardchild
@bstardchild
Jan 30, 2016 15:50:03 GMT
Not a problem,it'd be boring if we all liked the same. Yeah true - I love the previous Carltons and Senators and seriously considered getting an Omega but I hoped the styling would grow on me but never did and that V6 engine put me off as it has some "issues"
Jan 30, 2016 22:23:54 GMT
used to have a 1990 Carlton gsi 24v back in the day,4 years of trouble free motoring.
sorted the cam gaskets and replaced the coil pack,now runs like a swiss watch. had a look under the rear end and was pleasantly surprised at the lack of oil leaks bar one ,not much to do here. other jobs on the to do list are adjust handbrake,service the brakes and fit a set of 17" face-lift elite alloys from my shed of spares as they have much better tread than the existing 16's John
Apr 19, 2016 19:50:10 GMT
replaced the shagged out front speakers John.
village
Always carries a toolbox. Because Volkswagen.......
Apr 20, 2016 10:30:36 GMT
I had a Cav V6 with a misfire and leaking cam covers (and a bunch of other iffy bits), but I loved it dearly, even if it only did 23mpg, it sounded pretty fine IMHO
"The White Van is strong with this one...."
Chris "Chesney" Allen 1976-2005 RIP
