Hi,
After someone breaking a 940 turbo ideally 1990-1992. My ones got hunting at idle and cold start problems so need to swap out afr, idle control, exhaust canister and boost hoses if available. Also my speedo has stopped working so need a worker or one to pull apart. Its the one with gaps between the odometer readings. Also need a few other bits.
Anyone local to essex would be great, otherwise if your happy to post let me know.
Cheers
Dan
Cheers
Dan
