Jan 23, 2016 16:58:51 GMT
1978 1500 MG midget 1990 volvo 740 gle estate daily 1970 Ford Cortina mk2 practical classic 1970 Mini 1275 GT longtime project
sleag40
I've no longer space for any more!
Jan 23, 2016 17:12:08 GMT
Definitely got more structural strength from the filler than the body! Good luck with the repairs.
1994 Volkswagen Polo G40 1992 Volkswagen Polo G40 1988 Vauxhall Cavalier GLi 1977 Vauxhall Cavalier GL 1967 Lambretta SX200 1966 Lambretta TV200 1964 Lambretta LI150
Jan 23, 2016 17:12:41 GMT
Jan 23, 2016 17:22:15 GMT
omega
Jan 23, 2016 17:28:33 GMT
you are a brave man
Jan 23, 2016 17:35:39 GMT
so onto the rear wing, when the filler was cut off i found this no inner wing but only the front of the arch but i found more rust with the 2015 car show season looming more panels where needed so using some thing i did on the cortina i cut the rear arch of the passenger side to repair the inner wing but after more poking (I've got to leave the screwdriver alone) more rust in the arch was found with not much time left I changed back to the cortina and left this until the winter needing to buy the rear arch panel, so this winters work 2015/2016 needs to be up loaded now
Jan 23, 2016 17:45:32 GMT
Ouch,i love Midgets but i'm sure BL just made a water trap with wheels and so many seem to have been subjected to the worst kind of bodgery Brave man,i salute you !
jpsmit
Jan 24, 2016 21:39:11 GMT
You are mad! I mean that in a (mostly) good way. I don't think i have ever seen anyone bring a Midget back from that much rust - particularly a rubber bumper. Kudos! And, may I suggest that if you are doing that much work that you convert it to chrome bumper.
Jan 25, 2016 22:05:48 GMT
Jan 25, 2016 22:13:10 GMT
sill ready to be removed yep as bad as it looked but once the grot was cut out and a new bit cut and tacked in then welded up now attached to a new bit at the top and that's as it is at the moment
Jan 25, 2016 23:45:21 GMT
Think I'd have thrown in the towel long before this point.
Good luck with this one, makes mine seem like a piece of cake!
Another one saved keep up the good work
2
Feb 10, 2016 22:51:51 GMT
brc76
I'm amazed that had 12 months ticket on it when you got it. Brave work man
Feb 15, 2016 21:50:17 GMT
due to weather and the fence was fallen over i didnt get much time on it this weekend but i managed to sling on the passenger outer wing lip and the rear corner
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Feb 15, 2016 21:52:51 GMT
Amazing work to save this Hero!
Feb 15, 2016 22:28:37 GMT
If Stevie Wonder did MOTs.......Huge amount of work going on, keep up the good work
