1986 BMW M535i manual Pacific Blue Sports leather OBC Cruise Control Style 32 17" alloys Bodykit is to follow, so wait until its advertised please. Manual - gearbox specifics to follow. LSD Working cluster All panels are rotten. Fairly decent headlights Shadowline door trim and back lights. 1983 BMW 635csi manual Bumpers are sold, as is the manual gearbox. Wings are shot (no surprise). pacific blue interior (rear seats sold) good rear lights good chrome trims engine is complete and runs (ECU gone) headlights are good HLWW complete but untested good instrument cluster can get more pictures on demand.
p1erce
Can I get a price for the m535i flywheel, m30b35 idle valve + rubber hose/boot, and the MAF,
Thank you.
p1erce
And m30b35 exhaust manifold and sump.
(all m30 bits to come from the 535)
(completely understand if you don't want to break the engine)
What condition are the bottom corners of the rear screen surround, I'm after the metalwork that the screen sits in.
Can I get a price for the m535i flywheel, m30b35 idle valve + rubber hose/boot, and the MAF, And m30b35 exhaust manifold and sump. (all m30 bits to come from the 535) (completely understand if you don't want to break the engine) You're right in that I'm not going to break a running engine but still, should have a single mass flywheel which I'll make sure of, and as for the other parts you say M30B35 but both these cars are B34, the B35 is the E32/34 version - is that what you're after? I will have all the bits either way but they are different between the two engines. What condition are the bottom corners of the rear screen surround, I'm after the metalwork that the screen sits in. Which car?
What is the 5th ratio on the 535i's, is it 1:1 with dogleg? Also post 82 so i imagine it'll be electric speedo drive?
Potentially interested with the complete cradle , price on that would be great.
'73 3.0CS '81 Golf Gti 1.6 '83 Golf 20VT '87 M535i '86 Escort RS Turbo
What is the 5th ratio on the 535i's, is it 1:1 with dogleg? Also post 82 so i imagine it'll be electric speedo drive? Potentially interested with the complete cradle , price on that would be great. This isn't a dogleg box and yes all E28s are electric speedo off the diff.
What is the 5th ratio on the 535i's, is it 1:1 with dogleg? Also post 82 so i imagine it'll be electric speedo drive? Potentially interested with the complete cradle , price on that would be great. This isn't a dogleg box and yes all E28s are electric speedo off the diff. Ok mate,I presume overdrive unit then? Also does it have the bung/mechanical speedo blank on the box?
Rich
Club RR Member Number: 160
Breaking E28 M535i, E24 635csiRich
@foxmcintyre
Club Retro Rides Member 160
This isn't a dogleg box and yes all E28s are electric speedo off the diff. Ok mate,I presume overdrive unit then? Also does it have the bung/mechanical speedo blank on the box? It'll be a 5 speed, just laid out as normal, the dogleg was called by BMW 'sports gearbox' [read the owners manual last night- sad curse word ]
This isn't a dogleg box and yes all E28s are electric speedo off the diff. Ok mate,I presume overdrive unit then? Also does it have the bung/mechanical speedo blank on the box? Yes to o/d, no to the other. Short answer is, it won't suit the E9 if that's your plan. You need a pre-84 box for that. I did have one up until it Christmas but it went off to Poland to go into a Ford - prices for those boxes are into four figures now.
Ah no worries then matey, thanks anyway!
Jan 11, 2016 23:02:48 GMT
I'm after bits off the e28, if possible?
Jan 13, 2016 10:35:02 GMT
Yes,what bits?
Jan 14, 2016 21:35:01 GMT
Converting the E9 to electronic speedo is far far easier than building a speedo drive into a box that never had one from the factory. You'll use three gearboxes to make one IIRC.
Rich
@foxmcintyre
Jan 15, 2016 19:01:56 GMT
Cluster arrived this morning, cheers dude, off to Maplin now for a battery holder
Hi, This is my first post on the site. I bought a BMW 635 off the site in October and love it!! - retrorides.proboards.com/thread/183384/manual-speed-powerflow-exhaust-heathrowI'll post a project thread as soon as I get time to get out and get some pics. I'm after the door hinges and locators off your 635 if they're any good...? I may be interested in some other parts too, funds permitting - are you going to have this car around for a little while? Thanks, Rik
