As ever I’ve got too much stuff, so time for a clear out. In no rush to sell, so no silly offers please All parts can be collected from near Stratford-upon-Avon, or you’re welcome to arrange a courier.
If you want more photos, info etc. please PM me
Set of 5 Ford fit ‘Minilite’ wheels, 4x108 6x13, ET16 with steel inserts made by Revolution Motorsport. Very few miles, all straight and 4 in good condition. Paint on one rim is badly scratched, but not deep. Few marks on the others, but nothing major, most will buff out – would be mint with a coat of paint. SOLD
Set of 5 Caterham 7 wheels, 4x3.75” (4x95.25), 6x13”, ET24. Four are in very good condition with great original satin black paint, couple of chips in the centre caps. Fifth is a older spare, was orange, paint poor but straight, has an old R888 tyre fitted. These will also fit Triumphs, Metro, Maestro, Montego, Marina, Lotus etc. Say £200 ONO as well?
Set of 5 Hoosier semi slick tyres. Sport TD, A70-13 size (similar to 195/60/13) barely used, with 5.4mm tread depth remaining. Be a fantastic set of track day tyres, selling as not eligible for the series I’m going to be running in and I have loads of other tyres. Cost over £400 new, but been sat a while so £100?
Universal centre console, was fitted to a Chevette. Very retro with nice old switches, but not exactly a quality item, flocking is getting thin. SOLD
Ford Capri Mk1 pre-facelift front bumper with overriders, and mounting bars from a GTXL. Nice straight bumper, but chrome is getting thin/pitting. Also has one large scratch. Ideal for re-chroming, but looks ok if you’re not bothered about a perfect part. £70
Ford Capri Mk1 pre-facelift rear bumper with overriders and mount brackets from a GTXL. Nice straight bumper, but heavily pitted, ideal for re-chroming. £50
Large carbon airbox from a Mosler supercar. Been cut about and modified, but still very usable and certainly a talking point! Uses a Range Rover Sport filter from memory, but need to check this! No idea what it’s worth, £50?
Capri Mk1 pre-facelift dummy side vents. Nice and straight, benefit a polish. Comes with all the original, unbroken fixings – when was the last time you saw these?! £50
Mk2 Capri Sport front LH spoiler piece, plus a broken one. Useful spare? £10
Mk1 Capri pre-facelift headlight surrounds, cowling and chrome finisher, solid and straight but need polishing/painting. £30
Crossflow single choke carb air filter housing, £10
Pinto front cover £5
Another Pinto front cover £5
Pinto top cover SOLD
Crossflow 4 into 1 exhaust manifold, has been welded up but still works fine, £20
Capri -2” or Escort RS -3” front springs 200lb Provisionally SOLD
Mk2 Escort GL dash trim £10
Selection of Mk1 Capri pre-facelift chrome, side window trims are twisted, and one has a very bad kink in it. £10
Ford Pinto twin choke weber air filter housing, old style £20
Capri Mk1 battery tray and support, spot welds drilled out so can be refitted neatly. Totally solid, just needs a good clean. £20
Capri Mk1 Fuel flap. Very clean and rot free, even the spring is good. £10
Ford Crossflow GT twin choke inlet manifold £20
Ford Capri Mk1 Crossflow engine mount brackets £10
Ford Capri Mk1, Cortina Mk2, Escort master cylinder and 8” servo, condition unknown £10
Ford Crossflow Formula Ford 1600 exhaust manifold, perfect for making big power. Could easily be modified to fit lots of applications, or good start point for any 4 cylinder manifold? SOLD
