as it says really. it was in a 'rod, and removed less than a year ago for a manual conversion. was fully working prior to removal but i cant prove this. has aeroquip fittings at both ends of the oil cooler lines, and blue aeroquip hose. has a kickdown linkage setup on it, and the dipstick setup is an aftermarket braided steel flexi-setup. this bits alone are worth a few quid.
its still got some fluid in it, wasnt stored dry.
i cant prove its history at all and it isnt much use to me, hence its only £75 to get it gone. can pallet up but youre responsible for the courier.
location is manningtree, north essex.
