Friend took it to his garage where he works-gave it a once over and it needs two bits of welding and a set of pads for the mot-booked in for the first week in Jan.
Better than I thought.
Other issues.
Will need a centre bearing and holder for the prop.
Speedo-the speedo is original Royale but the engine and box are Monza 3.0i-there is an electronic take off the box-any ideas on how to get a speedo working?
Heater not blowing hot or even luke warm-even when engine up to temp.
Gearbox rear seal leaking.
Strange feeling through the steering such as worn rubber mountings/bushes you can sometimes feel it through the wheel and hear it especially when on full lock-feels a bit similar to the front bush problems on mark 3 Granadas.
Any advice on the above would be more than welcome!
Regards
Steve
Other issues.
Regards
Steve
