heathrobinson
Broken everything
Club RR Member Number: 111
Nov 11, 2015 20:46:40 GMT
Hi all. After getting a bit of grinder-propelled metal get under my goggles twice in as many days (one of which resulted in a trip to get it poked out with a needle in A&E...) I think I need some better goggles.
I'm after something that doesn't cost the earth (they will get scratched, I'm not always careful.), that fits my slim visage (skinny mush in English) and doesn't steam up too much. And obviously doesn't let stuff embed it's self in my eyeballs.
What do you guys use, and how do you like them?
Wilk
Nov 11, 2015 21:16:01 GMT
Oakley motocross goggles....perfect for task
They're vented to stop them steaming up, adjustable strap and you can get replacement shatterproof lens so they'll last you ages. The surrounds have foam cushioning to fit to your face to keep out debris
Last Edit: Nov 11, 2015 21:17:36 GMT by Wilk
Nov 11, 2015 21:29:40 GMT
Don't know about using them for grinding but Oakley snowboard googles used to be about half the price of the mx ones....I used safety specs with yellow lenses as it seems to make things brighter and make me happier,
Nov 11, 2015 21:41:02 GMT
From your description were you wearing protective glasses as opposed to full goggles?
Anything with the correct safety mark will do. You pay more for ones that don't mist up (never work!) or have a 'designer' name. My goggles were an ALDI buy and do a good job. Scan screwfix for something
omega
Nov 11, 2015 21:45:32 GMT
sorry guys but I have to disagree goggles are better than nothing but you should really use a full face mask. yes you look a curse word and sometimes it gets in the way but you keep your eyes and face safe.i had a disc shatter and still have the gouge in the mask. better the mask than your face.
heathrobinson
Broken everything
Nov 11, 2015 22:36:06 GMT
I've got one of those yellow-topped full face jobs, but it pisses me off no end. Not great with a mask under either, and gets in the way of my ear defenders. I tend to only use it with cutting/slitting discs - never heard of a thick grinding disc or flap disc etc. shattering in the same way, and I never use cheapo high-speed consumables after a carbide disc fell apart before I'd even got it near the work piece. It's also pretty cheap, and I'm not sure how much I trust it... Good shout on the MX goggles, I saw a set with a bashed up lens at the car boot a while ago, should have picked them up! I've had a few different pairs of safety goggles, but most either don't fit, are uncomfortable after 20 mins, steam up immediately, or get in the way of ear defenders. Thought it worth asking, as I can't be the only fussy skinny git on here that's had this problem. Cheers for the replies.
Nov 11, 2015 22:37:36 GMT
Hi all. After getting a bit of grinder-propelled metal get under my goggles twice in as many days (one of which resulted in a trip to get it poked out with a needle in A&E...) I think I need some better goggles. I feel your pain. Those basic goggles seem to let debris in around the nose, or at least that's how I ended up on my particular little A&E adventure. I stopped using them after that, and got some DeWalt goggles. Not crazy expensive, comfortable to wear, seem to hold up pretty well to scratches and the like, and don't fog up. And most importantly keeps shards of metal from embedding themselves into your eyeball, which is great. I'm about ready for a new pair after a year and a half's abuse but they've been used quite a lot, I'll probably buy another pair of the same.
Nov 11, 2015 22:43:10 GMT
Last Edit: Nov 11, 2015 22:45:04 GMT by fordperv
heathrobinson
Broken everything
Nov 11, 2015 22:43:44 GMT
Not fun is it. The point when he's waving a needle at my eyeball and says "now hold still - if you twitch I might blind you" wasn't reassuring!
Nov 11, 2015 22:51:05 GMT
Those were the sort I was wearing when I got metal in my eye. They don't form a good enough seal to keep debris out, particularly if it's going at high speed. I don't think they were particularly cheap pair either.
Nov 11, 2015 22:52:03 GMT
Depends on the situation, but i used to use goggles for light work (lowish risk) if it was anything abit heavy going or i was in an awkward space i had an old welding mask just with the small clear lens that id wear (also great when your laid on your back with a blow torch scraping underseal off). everyone has there own preference's but id try and protect my hole face whenever possible
Not fun is it. The point when he's waving a needle at my eyeball and says "now hold still - if you twitch I might blind you" wasn't reassuring! Are we related? Not for the first time I have had metal in my eyes, a couple of months ago a shard worked its was in past the googles and under my eyelid, 6 weeks later I'm back in eye casualty with a deep scratch on my cornier but not sure how that happened the scratch got infected and I'm now on a month long course of eye ointment.
edwell
Nov 12, 2015 12:27:05 GMT
I got some Bolle one from amazon for less than a tenner, seem OK for light to medium duty Bolle Goggles - amazon
Nov 12, 2015 12:28:49 GMT
Never had any issues with my ski goggles I bought at a flea market
Nov 12, 2015 12:33:34 GMT
I have proper prescription safety glasses with give me basic protection but also use non direct vented goggles. Cheap but don't suffer as bad steaming up as direct vented type
steveg
Nov 12, 2015 14:39:48 GMT
I've got bits in my eyes from grinding a couple of times recently. I now have some well fitting goggles the old ones had the odd gap,must have a weird shape face ! I also have a proper face shield. I might have told this before but the second time I got A&E to remove the bits with a needle I realised the anaesthetic hadn't worked the previous time they did it !
One thing to watch is that you don't get loads of junk caught in your hair, you can end up getting bits in your eyes when you have finished and taking a shower.
Nov 12, 2015 15:56:59 GMT
I got some Bolle one from amazon for less than a tenner, seem OK for light to medium duty Bolle Goggles - amazonGot these, they're brilliant. They do an insert that you get an optician to make prescription lenses for and you have prescription goggles. I use them for light work, dusty stuff or working under the car where rust and dust might fall on you, but for any mechanical cutting or grinding I always use a full face mask. It's not even an expensive one I've got. The guy I share my workshop with has done the "hold still, I don't want to blind you" thing at A&E and I got my self protected after that.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Nov 12, 2015 16:03:39 GMT
I'm a very naughty boy tbh. I don't use goggles at all. Very occasionally I'll use my welding mask if i can't avoid stuff flying at my face.
I should/do know better, having had bits dug out of my eye a couple of times now (one time was embedded in the lens covering of my eye :/ ) but I find them clumbersome and almost dangerous themselves by restricting my vision through being blurred or steamed up
Nov 12, 2015 19:09:16 GMT
Being a speccy I always wear a full-face mask. I do spend a fair bit replacing scratched/pitted shields, but I like my eyes the way they are.
