Nov 10, 2015 22:15:43 GMT
i need some coilover springs with an id of 2.5 inches and length of over 9 inches does anyone know a good cheap supplier of these or has anyone got any knocking about. did any cars use this size as standard
i am trying to convert my opel gt from leaf spring to coil over using a kit and the origional shocks
thanks.
Nov 10, 2015 23:01:45 GMT
thats a pretty common size range, but you do need to figure out what spring rate you need.
any motorsport supplier should be able to sort you out, ebay, merlinmotorsport, any eibach dealer, demon tweeks etc.
choptop
having fun in a 61
Nov 11, 2015 12:28:13 GMT
coilover springsDeleted
@Deleted
Nov 11, 2015 19:34:28 GMT
Another vote for Faulkner springs. Good quality and service.
Nov 19, 2015 15:12:39 GMT
I have some 500lbs coilovers springs 2.5 diameter but 7in long if there any good
Nov 20, 2015 20:41:16 GMT
I have some 500lbs coilovers springs 2.5 diameter but 7in long if there any good Thanks for the info but ive picked up a pair of 10 inch long 325 lb ones off ebay for 18 quid. cheers
Nov 25, 2015 14:56:23 GMT
bargain
eg2
Nov 25, 2015 23:39:53 GMT
if those aren't stiff enough I have some 450lb 10.5" ones for £20
Nov 25, 2015 23:52:16 GMT
if those aren't stiff enough I have some 450lb 10.5" ones for £20 I am interested in these if sunbuilder isnt Sent from my SM-G920F using proboards
mk2cossie
Club RR Member Number: 77
coilover springsmk2cossie
@mk2cossie
Club Retro Rides Member 77
Nov 26, 2015 17:29:17 GMT
I have some 750lb 7inch springs if they are of any use to anyone?
Nov 26, 2015 20:31:37 GMT
Thanks for the offer eg2 but it will be a while before i have the car on the road,as i am restoring, repainting it, so I think you should sell them to 1980 escort. Cheers
eg2
Nov 26, 2015 20:47:29 GMT
if those aren't stiff enough I have some 450lb 10.5" ones for £20 I am interested in these if sunbuilder isnt Sent from my SM-G920F using proboards All yours if you want them then chap, drop me a pm
