This is a set of four genuine Mini R90 BBS two-piece alloy wheels as fitted to the BMW Mini. They are not replicas or one-piece but the real two-piece version.
Complete with genuine BBS stamped wheel bolts on each wheel.
Specification is:
PCD: 4 x 100
Diameter: 17”
Width: 7”
ET: 48mm
They are fitted with four run flat tyres:
3 x Pirelli at 6mm, 6mm and 4mm
1 x Hankook S1 Evo at 6mm
The wheels are in excellent unkerbed condition but they have suffered the usual outer rim dulling/peeling. They all look dark in the photos as I’ve just washed them. The outer rim can easily be polished or painted, probably without even removing the tyre, once the two parts have been separated.
The wheel centres and centre caps are in good condition as the photos show.
These wheels are sought after and look stunning when refurbed and polished.
Will fit many other cars with a 4x100 stud pattern including VW, MG and Vauxhall. However please check for yourself before buying.
Specification is:
PCD: 4 x 100
Diameter: 17”
Width: 7”
ET: 48mm
