Sept 12, 2015 11:42:47 GMT
Can anyone help with the retro fit of an oil pressure gauge? The sender and gauge connections are below, the gauge needs 2 feeds from the sender (sensor - and +) but it also needs a feed from both connections of the warning light. The sender has 2 connections, Gauge and Warning Light. Is one of these, "Sensor -" or is it the wrong sender for the gauge? The ideal solution is to remove the car's original warning light sender and replace with this new one that does the gauge and warning light together.
benjy_b
Yorkshire and The Humber
Sept 12, 2015 12:07:53 GMT
WK = Warnkontakt (presumably, warning contact) A quick google search ( link) reveals this:
Last Edit: Sept 12, 2015 12:15:08 GMT by benjy_b
2005 Subaru Forester 2.5XT 1999 BMW E36 318i Touring with OM605 Mercedes Engine 1996 Lada Riva with Honda S2000 Engine
Sept 13, 2015 19:27:34 GMT
Yes, I think the problem is that the gauge wiring is different to that diagram. Think I've made sense of it though!
frag
Sept 13, 2015 19:58:27 GMT
This is not correct, Gauge needs an ignition live to + Earth connection to - Then the terminal marked G to the G on sender, (So only 1 wire between sender and gauge) Sender earths thru engine.
Warning light needs an ignition feed to bulb, Other side of bulb to WK terminal (Which will be an earth with no pressure,thus lighting the bulb)
The wiring diagram with gauge is confusing at the best ! Sensor ground / sensor signal ? Sensor signal is a ground,sensor grounds itself.
Last Edit: Sept 13, 2015 20:07:22 GMT by frag
'69 Holdsworth bay '88 T25 Panel van ‘72 beetle ‘78 vw champagne T2
Sept 13, 2015 22:11:52 GMT
Anybody know if those combined pressure and warning light senders are available separately in ford fitment 1/8 NPT I think
benjy_b
Sept 13, 2015 22:25:59 GMT
Anybody know if those combined pressure and warning light senders are available separately in ford fitment 1/8 NPT I think Yes
hario
S202 C300STD
Sept 14, 2015 11:37:04 GMT
G - Gauge (pressure transducer, wire to gauge readout [labelled as sensor]) WK - warning light (low oil pressure switch [wire to warning light])
The gauge must also be earthed to the engine block for reliable readings.
Which bit are you confused by?
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
Sept 17, 2015 5:32:25 GMT
I was confused by "Sensor minus"
hario
S202 C300STD
Sept 17, 2015 9:55:24 GMT
It says on the key: Pin 3 - Signal Ground - blue/black. Basically the sensor and gauge must be earthed together then to GND because there may be a potential difference between body ground and engine ground for various reasons, and the gauge measures such a small voltage across the sensor that it could drastically alter the readout
