Hi,
All removed from my mk1 escort and was running nicely when removed. Since then just been sitting in my garage for a couple of months. Can sell in bits but can do a deal if someone wants it all. Collection from CM77
First is a 711 crossflow with 1300 +60 pistons, BCF2 cam and lightly ported GT head not sure on value so £500. Done less than 10,000 since being built. Also has electric conversion on dizzy and clutch to run a type 9 box.
Bike carb setup for the above engine. Thunderbird carbs with the bike mounting rubbers and manifold to suit. Also has a cut down bike airbox, not the best looking but functional. Also including the correct fuel pump. £150
Ashley 4 branch manifold £40
Starter for said engine £20
Type 9 gearbox with cast bellhousing, gearstick, clutch release fork and bearing for said engine £200
Mk1 escort boot lid with abit of rust on the bottom edge and a dent on the back where the filler has cracked off £50 (lock and ford badge will be removed)
Downdraught weber 32/34 in working order was on the crossflow before the bike carbs. £60 with manifold, airfilter and throttle bits and bobs. Converted to manual choke.
2 Piece prop for type 9 to big flange english £20
I also have a classic mini exhaust i'm getting shot off and a 998 a series engine for £100
Can probably do a deal on all the bits together.
