I have a brand new battery box which can be used to relocate the battery to anywhere in the car £25
(Left of Pic) Battery cutoff switch and Hi-Flex 25mm2 battery cables. High quality CE stamped cables and switch, seen one season of use on a BDC drift car. This would be perfect to relocate the batter to the boot etc. Cable lengths are:
Black Earth: 50cm (20")
Red Cable 1: 109cm (43")
Red Cable 2: 280cm (110")
£35
Both the above for £50
(Right of pic) Battery cutoff switch and battery cables. This came out of my MGB and is perfect for either fitting a remote cutoff switch in the cabin and/or relocating the battery. Cable lengths:
Black: 216cm (85")
Red: 127cm (50")
£20
£35
Black: 216cm (85")
Red: 127cm (50")
£20
