buying the original engine for my 180 so this lot needs to go
collection st.albans
paypal accepted
prices are not including postage
ca18det engine pulled from a low milage 88k
ive replace
timing belt gates
oil castrol 10/40
oil filter
rear crank seal
thrust bearing
since the above ive covered about 200miles the engine is faultless . nice and smooth
no knocks or bangs or leaks
starts off the key.
I'm asking £400ovno it wont come with pas,alternator or starter so just the tall block.
autobhan fmic with custom pipework £150
ca standard rad £30
ca starter motor £40
x2 ca alternators ,£30 each
pas pump £20
ca transistor the one on the arch by turbo £30
ca red silcone hoses with adaptor for gauge £35
ca 4 pin maf £35
ca standard ecu £20
ca prefacelift loom it has been spliced into my loom but ive kept the plugs so i will join them back up properly £80
ngk stage 6 plugs will double check £25
custom intake pipe for t04b £30
ca gearbox loom £50
ca bell housing with bolts £60
exedy stage 1 clutch seen 500miles £60
turbo stuff here www.sxoc.com/vbb/showthread.php?581472-ca18det-topmount-setup-%28manifold-turbo-elbow-braided-line
paypal accepted
ive replace
timing belt gates
oil castrol 10/40
oil filter
rear crank seal
thrust bearing
starts off the key.
ca standard rad £30
pas pump £20
ca 4 pin maf £35
ca standard ecu £20
ca gearbox loom £50
