mt2man
Well i originally cut the sides out for this project from some marine ply about 5 years ago, but a couple of house moves and too many other projects i never got round to finishing it. I had planned on taking my camper to the gathering but cant sort reasonable insurance so decided its about time i got the tear drop going again for somehwere nicer to sleep! So last week i managed to buy a 5x4 foot trailer for £30 and started the build again! It will be towed behind my 1977 Toyota Corona so i will be bringing something retro to the gathering This is an extreme budget build. The marine ply was salvaged (free) the trailer was £30 and hoping to get it finished for under £100. Ill let the pictures do the talking! Rough shape on the ply. Sides cut out Then i got a trailer, had to strip the wood, i red oxide the whole frame and then re boarded the base. Started adding the sides. Added some supports. Forgot i had to cut a door hole.... So attached it back to the trailer again and started cladding it. (Cheapish soffit board) And thats as far as ive got in the last week! Hopefully 2 weeks left is long enough to get it finished, although ive just badly burnt my hand at work so trying to do everything your self 1 handed is a struggle haha. Now will it get done in time?! And a couple pics of the tow vehicle
mt2man
Forgot to say the bed dimensions are 6x4 so I'm extening the floor the extra foot needed at the back. Its currently still front heavy ever so slithly, i was worried about nose weight and the position of the wheel, but once the floor is added I'm pretty sure its going to be pretty much 50/50 weight balance. Not sure how its going to tow but the journey to the gathering will show me that haha! Its very easy to move atm, 2 people can still lift the whole trailer so should be sub 200kg all in i recon which is nothing for the Corona
I've got a couple of trailer chassis and keep meaning to get one started, one day :/
mt2man
Do it! They're good fun and different. As I say this is a bargain build so it won't be perfect, but it's still fairly light weight and should be fun for weekends away!
Bloody good speed there.
You can do it.
Bookmarked. Interested to see how this turns out, you've got my mental cogs whirring now...! I fancy having a do myself.
Al.
I'd love to build one of these to go behind my Wolseley 1300. Seen plenty of inspirational ideas both here and on another forum I frequent. I dig your tow car too. Does it have the 18R 2.0 litre and 4 speed manual box? My dad bought '76 one second hand in 1980 and it was a good car. Was good for an honest ton on the highway too. I once had the speedo indicating 180 km/hr but I didn't tell him until after he sold it.
mt2man
Thanks guys! The tow car has the 18R 2.0 but it's a 5 speed! There's not many about at all. So far it's proven to be one of my most reliable cars, I'm having to use t daily whilst my Lexus has decided it doesn't want to run properly haha
mt2man
Few more updates, it because a family job today due to my hand! haha Ill let the pictures do the talking... Had to extend the floor by a foot, looks abit bodged but its solid also added insulation, whole floor will be done. This curve was a pain, ended up with a kink but some silicone will hide most of it, it was never going to be perfect. And its cladded! Still got alot to do before its finished but its getting there! Got a few vents, and need to put a window in the door and sort hinges and a lock etc, finish insulation, sort carpet, wheel arches, etc etc. Probably wont be fully finished for the gathering but finished enough to sleep in
I may have built one before, but I also know I made couple (well a lot) of errors building it.
Firstly, I did not know, or underestimated he amount of energy generated by the human body.
See you insulating, unless it's just a means to an end to get it weather proof, be careful. That trailer will be so hot once done and slept inside of.
Nicola and I found that together we had to leave the roof vent and door open most of the time when sleeping in even deepest autumnal weather.
Ensure you have a couple of decent, openable vents on both sides.
Regarding windows or portholes, get yourself an old caravan window, they are clear polycarbonate ( I cannot see where in the country you are) , but have a spare out behind the garage that you can have. Alternately, there are caravan breakers everywhere.
I used four Poundland wall clock wooden surrounds to make my porthole frames, ready cut in wood, at a cost of £4.00 which was less than the time and effort would have cost me.
Not sure what door handle you are going to use either.
And another thing, if you are painting the inside of the wood, get the first coat on now already for it to dry unless you use solvent and smell free paint/varnish....... The smell stays a long time and you do not want to wake with a solvent induced headache.
If you have not thought about it, find some ally strip,like carpet edging, door or window frame or similar and make a little silicone sealed and screwed ridge above the door to help rain bypass the inside. Water will find a way inside to mess with your bed and head.
Good to see the family helping too.
mt2man
Cheers for the feedback! The insulation was originally just to raise the level of the floor over the trailer frame so the mattress lays flat haha I've got vents for it so should be breathable, I've got a mesh door cover I was going to trim down and Velcro around the door hole, I'll probably sleep with the door open anyway! Just want to keep bugs out. (If it's not raining haha) Didn't think about the clock idea but that's a good idea! Might have to go have a look around still undecided on door locks. I don't want it lockable from the outside whilst I'm inside, camping with friends they would lock me in. Haha Also unsure which side to hinge from, don't want a wind trap up the door and force it open etc whilst on the motorway so may have hinge it the opposite way than j was planning. I had planned to run a channel over the top of the door
mt2man
Aug 16, 2015 19:53:27 GMT
Well it's somewhat ready for the gathering! Just need some tyres fitted ready So far spending is at £90.73 as I had to buy a new trailer board, hinges and a lock. By the time I've got tyres I'll be over budget, but can't complain too much! Been watching home made tear drops sell on eBay for £800-1100!
bazzateer
Imping along sans Vogue
Aug 21, 2015 18:01:09 GMT
Pics?
Russ
Aug 21, 2015 21:42:46 GMT
Saw this today, passed you in Worcester. Looks good
mt2man
Got this finished, probably going to sell it ready for people to enjoy in the summer
mt2man
Jan 12, 2016 20:44:00 GMT
How much do people value tear drop trailer?? They seem to be £1400+ on eBay?! Thinking of putting this up for sale soon as I need a new boiler
