stevietuck
Never argue with idiots,they drag you down to their level then beat you with their expertise!
Jul 24, 2015 16:21:33 GMT
Hi folks, I have been thinking about getting a pug 205 diesel for a while now. I would want to lower it front and rear and my question is this . . . how interchangeable are gti front struts, hubs and brakes? I understand the lesser 205s have a track control arm with the anti roll bar mounted through it where as the gti has wish bones and an antiroll bar with drop links, is this right? Can you swap to the gti set up without changing the hub carrier? And if i don't change the carrier can i fit bigger discs and callipers? and gti anti rollbar? Whats in my mind it a gti rep (ish) on a diesel then look at td engine swap. So any pug fans had any experience with this type of thing? Cheers Steve.
Jul 24, 2015 16:53:03 GMT
From memory, the struts are the same apart from ARB tab is on the GTI strut, same main mountings though.
I'm pretty sure you can swap to the GTI setup without changing the hub carrier and you should be able to fit brakes from the GTI, but I think you have to do a bit of mix and match to get the disc offset right something like you can fit the 1.6 GTI calipers (which are the same as the base model but with a wider carrier for the vented discs) with 1.9 discs. Or you fit some of the other larger Pug/Citroen brakes from 306's/xsara's etc.
I'm sure someone will correct me on some of that as it's been years now since i've had a 205. What diesel is yours now? I think the DTurbo and maybe the STDT already had the GTI front suspension.
Last Edit: Jul 24, 2015 16:55:11 GMT by georgexs
96 Peugeot 405 Executive DTurbo Estate 89 Mazda Eunos Roadster 88 Citroen BX 16RS Previously Owned: 93 Subaru MV96 Disco 300TDI 72 LR SIII 109" Prima96 Xantia Activa 92 AX GTI 97 ZX Temptation 88 205 XS
stevietuck
Jul 24, 2015 17:16:25 GMT
Thanks George, Ive not bought one yet lol! I'm still at the trawling through ebay/ gumtree/ anywhere else stage at the mo I'm going to be on a tight budget ( I'm starting college soon at 45 scary!) and don't want to end up buying stuf twice because this bit wont fit with that etc. being skint is also the reason I'm thinking diesel as college is 25 miles away. Iv heard you can turbo the the non turbo engine but its cheaper to just swap the whole td engine and set up from the 306? Any info on this would also be welcomed. Thing is if I'm swapping an engine would it be easier to start with a diesel engined car ( they seem to be more money than petrol) or could i use a petrol model? Sorry for all the questions
jonxs
Jul 24, 2015 17:38:50 GMT
I believe what George said is right, it does sound it anyways. I think the turbo ones had gti setup and the na's had base model spec. Swapping petrol stuff to a diesel would be a bigger pain than you think, all the fuel lines and tank will need to be changed over. The engines mounts could be different on a derv to a petrol I cant remember right now haha. Swapping a diesel to a diesel would be ok, there's a few guys online that have done the swaps
jonxs
Jul 24, 2015 17:39:52 GMT
Or get a base model 205. They are really economical on fuel, even if they are a wee bit slow
stevietuck
Jul 24, 2015 17:51:30 GMT
I think some of the later petrol cars had single point fuel injection, so they would have fuel retun pipe to the tank would they? Like you say i think the diesel to diesel engine swap would be easier though. Iv heard you can get more power by adding an intercooler to the td engine?
jonxs
Jul 24, 2015 17:54:36 GMT
Yes I believe so. (not actually owned a injected one ) Yes adding a FMIC adds power, also if its a Bosch pump you can get more for free
stevietuck
Jul 24, 2015 17:58:42 GMT
Any info on the bosch pump? is that the veg oil friendly one?
jonxs
Jul 24, 2015 18:23:20 GMT
stevietuck
Jul 24, 2015 19:17:25 GMT
Thanks for the links jon il have a read.
stevietuck
There is some interesting stuf in those links, only thing is the dturbo engines seem quite rare compared to the amount of hdi engines out there and the hdi is not as easy to fit.
DTurbo is a trim spec, i.e the later 306 DTurbo had a HDI engine...
there never was a 406 "DTurbo" but there were millions with the 1.9 TD engine.
The XUD9TE engines aren't rare at all though are getting old now.
dropping a HDI in isn't difficult at all, it would be easier to start with a gti due to the electronics, and lift pump etc.
best bet is to look up on the 205gtidrivers forum, there's quite a few diesel perverts there too.
stevietuck
Jul 25, 2015 11:29:06 GMT
Thanks for that welshpug that clears up some of my confusion
Jul 25, 2015 15:45:44 GMT
why not just buy a 205 stdt, its the 1.8 td, but with gti looks, brakes and suspension (1.6 gti) some came with 1.6 gti wheels and others had 1.9 gti wheels. lovely cars, mine had the bosch pump, i don't know the stdt had the other pump (lucas i think).
stevietuck
Jul 25, 2015 15:53:35 GMT
i can only find 2 for sale in the uk and they are at least double the money. anyway where is the fun in that
Jul 25, 2015 16:01:39 GMT
i bought one off here quite a while ago, loved that car, just too slow for me.
i got it for £300 and did the headgasket. sold it for £1000 with bad paint.
fitting an hdi engine is easy enough, you wouldn't need a 2.0, id go for the 1.6 110 bhp. or go all out and fit a 2.2 hdi :L
stevietuck
Jul 25, 2015 16:21:40 GMT
Iv spent most of the last 2 days reading up on the 1.9td and the 2.0hdi and it looks like there is much fun to be had
Jul 25, 2015 17:36:02 GMT
Or youtube 2.1td 205. Goes quite well with the boost turned on.
Click picture for more
Jul 25, 2015 17:46:34 GMT
i bought one off here quite a while ago, loved that car, just too slow for me. i got it for £300 and did the headgasket. sold it for £1000 with bad paint. fitting an hdi engine is easy enough, you wouldn't need a 2.0, id go for the 1.6 110 bhp. or go all out and fit a 2.2 hdi :L unless you're a proper wizard with the electronics then the 1.6 is a no go as they were only ever in multiplexed engines, the 2.0 8v hdi was available in the 306 and phase1 xsara so can be had in non multiplex. 2.2 is a bit big for the 205, will be harder work to fit, you can run it on a 2.0 ecu mapped to suit.
That's half the fun though! Cant beat a good project.
