HI
I have asked this question on imoc but have had no luck with replies, the other two mr2 forums won't let me unless I give them some money
So I have cut away the outer sill and the center reinforcer is rusted away at the bottom. Did this return and have a flange that was welded to the lower flange of the inner sill and the outer sill flange was welded onto the top - so 3 flanges together? I actually doesn't look as if it was like this but I don't know what the inner reinforcer did, or rather where it went - if you know what I mean (even I'm confused)
Thanks in anticipation
Mark.
Mark.
