So i have the task of putting a 1983 911 Turbo together after the guy who stripped it did a runner, i have boxes of parts that i have sorted through but am a little stumped as to where these two panels go?
now the guy whom stripped the car made no reference to which parts of the car came off where and just put nuts, screws, trim, lights ( off which he just pulled the wiring from) and all the other parts just into boxes, i have had a Jigsaw puzzle to work through as well as finding parts damaged and broken,
so to the parts i need identifiying?
this side is made of hard card board, it has tabs which slide onto some part of the car, on the other edge are screw holes, the screws are black counter sunk,
this side is foam covered and also has a black plastic something (broken) screwed in?
You can see where it has been screwed to the panel squashing the foam in the bottom left of the picture,
this could end up a wild goose chase so please only reply if you know where these parts go,
many thanks
many thanks
