121k miles with full service history.
Has a new fan belt less than a year old probably only done a few hundred miles.
I can see score marks on the cam lobe through the oil filler cap but still ran and pulled well, needs a new rocker cover gasket as I took it off.
Consists of
Block and head with manifolds, the inlet manifold has no rubber carb base block and there is no dizzy.
The fuel pump is brand new but it stopped working after ten mins! So I don't know wether it just needs repriming or is actually dud. If it is broken then I have the original one which wasn't the cause of the problem in the end if someone wants to buy that.
£60 for the engine.
Also have the original coil for £15 posted and a brand new coil from vw heritage listed as suitable to fit all mk2 engines £20 posted.
Located in Worcester, pm me if interested.
Also have quite a few mk2 1.3 parts such as subframe complete with brakes, 1.3 fuel tank, 1.3 rear beam.
Consists of
£60 for the engine.
