got a few of these in a job lot.
points made by commercial ignition company limited. 1970s stock.
4x CS.132 contact set. replaces lucas 54423769, CS8.
huge list of applications from Austin, Daimler, Ford, Humber, jaguar, lotus, MG, reliant, rover, land rover, sunbeam, tvr, triumph, wolsley and others. check what points you car should, if any of the 3 numbers above are correct, they're the ones for you.
£5 each delivered.
2x CS.117, replaces lucas 54419946, again same long list of manufacturers, check your numbers and compare.
again £5 each delivered.
4x genuine lucas motostock C2 condensers. again 70s stock. ford applications, anglia, zodiac mk4, zephyr 4 and 6 mk4, escort 100/1300GT, cortina and capri 1300, 1600 and 1600GT. 5/7cwt van, escort van, transit 12/35cwt. £7.50 each posted.
£5 each delivered.
