Hi guys,
Got an annoying hot start issue which is making it a bit unpractical running the car at the moment.
Cold starts fine. Once up to running temperature however, it never sparks.
So, a few more details.;
The car is running a non ballasted coil. Fitted a brand new one to eliminate a faulty coil from the mix. Electric fuel pump. Twin Dellorto carbs. Lumen inion electronic ignition. Plugs just been cleaned and recapped. High torque starter motor.
Battery is newish but not a high capacity one.
The fuelling is a bit rich. Plugs were quite black.
I have heard of fuel vapour lock, but still not sure if that is what I am dealing with.
So, where would you guys start.
