May 19, 2015 21:26:40 GMT
Hi. Currently trying to build up my T25 camper project and after a set of old skool wheels. Really liking the look of some Slot Mags or Turbovecs, or something similarly old skool. Need to be in 5x112 fitment and VW or Merc centre bore, so at least 66mm or they wont fit. Let me know if you have anything. Thanks
May 20, 2015 20:00:23 GMT
got these in 14x8, but wobble bolts would be needed as they are 114.3
May 20, 2015 21:39:03 GMT
Whats the offset and centre bore mate? Could be interested if offset is high enough to use adaptors. They may be a bit wide for the bus though, think I'll have problems with suspension or arches, which is unfortunate as they are awesome.
May 21, 2015 19:47:18 GMT
4" backspace and centre bore is around 75mm
mig
May 23, 2015 20:13:57 GMT
Hi, I have a set of Turbovanes(?) 14x6 5x112 70mm center bore not sure of offset but they looked a good fit on the van Stamped on the back is 121 B 79 47.If you are interested I'll measure the ET. Really need a re-paint but wheels themselves are in good condition Based in Wembly but can get them to Manchester Sheffield or Nottingham fairly easily. I also have a set of slotmags 14x7 5x112 70mm center bore ET 31 but they are difficult for me to retrieve at the moment. one is proving difficult to seal(I am fairly sure it isn't porous as it is leaking at the rim seal.Really good load rated tyres new center caps. I don't really want to sell so I would need a really good offer to part with them.
Last Edit: May 23, 2015 20:15:39 GMT by mig
May 28, 2015 21:27:04 GMT
hardtop. Those are going to cause me massive fitment issues. Just too wide unfortunately.
mig. Thinking about it now 14's will be too small. Too much tyre not enough wheel.
May 29, 2015 16:04:29 GMT
Mig, if I may step in, I am interested in the turbo vanes. How much are you wanting for them?
mig
May 31, 2015 20:42:12 GMT
