Jul 14, 2018 21:07:02 GMT
Just beautiful. Still only halfway through the build thread but great to see latest news - the dash is incredible. Going to hunt down one of those little reverse lights for my rail.
Well done on the TVR manifold. The reduction in noise was a big clue it was going in the right direction (reduction in turbulence). Medusa is coming on, epic build! Time to revisit your back brakes though. There is an auto adjusting mechanism behind the shoes. Have a look through this www.londontaxipartsusa.com/images/brakes/Brakes.PDFThank you crockmiester , stuffed if i can find a veiwing port on the backplate of the drum , i will have another look ,mine is a fx4 freeway driver though .
It's been many years since I messed with these axles but I do recall that rear access holes could be a bit random. I had Westminster axles (same thing except for ratio) and some had them, some didn't. The self adjuster was not that good and could take a bit of patience to get right. Biggest issue was the snail cam teeth wore away. It would then slip to the least adjusted position (if that makes sense).
Jul 15, 2018 10:07:18 GMT
excellent info thank you , i know the shoes are being held close to the drum cos its a bit of a job to get it off , i am wondering if the handbrake cable on the o/s is a bit rusted to the outer ..
Jul 15, 2018 16:04:07 GMT
Congratulations for winning the golden bucket.
Jul 15, 2018 19:04:59 GMT
Thank Pete ! i didn't see that coming , i will have to find somewhere on the car to mount my bucket !
Jul 17, 2018 19:43:52 GMT
orl roighty .. faffed about a little more on the wiring front , strapped the sensors on the ally downpipes from the heads , and extended it all to the dash ,and tested it by blowing a blowtorch on the pipes ,and the readings changed so we shall see if its a go-er .. i as not really sure about the digitals , until i lit them up ,with the brass and wood grain contrast , now i like A LOT . made a neat cluster for the scuttle .. that's the feeds for two temps gauges ,and the speedo feed ,and the illumination led for the speedo.. rest of the wiring tidied up .. then panels back on .. oh yes also did the constant feed for the clock (which,AMAZINGLY, works),it only draws 1.4 mA , so should be ok . made a decoesque plate for the scuttle panels joint , and also experimented with making some brass plate look engine turned , i had asked v if ,when she went to the local sunday boot sale, she could find me some brass plate...., she only came back with 10 old door finger panels ,for 2 quid !! spectacular result . tomorrow hopefully get the cowls on (as robin said to batman after a delivery from their tailor.) regards robert.
Last Edit: Jul 17, 2018 19:46:58 GMT by ivanhoew
Jul 17, 2018 21:29:32 GMT
veronica DEMANDED i show her my lights
mk2cossie
Club RR Member Number: 77
Very nice progress there Although i must comment about your rather large nuts at the back ivanhoew! They are rather magnificent
veronica DEMANDED i show her my lights Well........ I saw no lights. But I certainly heard Veronica. No wonder you were so eager to please her. She sounds just lovely. Need to go look again to see what lights you spoke of.
Jul 18, 2018 19:57:36 GMT
cossie ! er thank you ? grizz , she is ! ok dokey ... got my cowls sort fo fitted today , firstly i attacked the beaten edges . before .. after .. then got to drillin and a fixin.. oh yes , and did my epileptic angle grinder pattern on the underside ,just to spiv it up a bit.. that was quite hard to get the nuts under the screws in the bit behind the dash , i may try and find ome m4 rivnuts tomorrow on t'net . very pleased to have got this sort of done , its anxious work drilling parts of the car that look good ,trying not to get it all wrong and wonky . regards robert
Jul 19, 2018 18:43:04 GMT
well fiddly work today , getting the screws screwed to the nuts on the underside was very tricky.. luckily i had my secret weapon veronica to come and use her little fingers to get them on .. then i had a bash at my mirror mount.. i was not sure if i liked it , but ,upon reflection decided i did ( see what i did there ? no ?? , oh well i'm here all week ) regards robert.
wodge
Love it! I think you could’ve found a niche in the market too - The Steam Punk Bra!
Now you've fitted that mirror, you will never look back
Now you've fitted that mirror, you will never look back oh thank god.... i thought i had lost my RnS crew in the emergency ...feel much better now
Last Edit: Jul 20, 2018 8:56:35 GMT by ivanhoew
Jul 20, 2018 10:04:35 GMT
Now that's done can you "see" yourself driving it?
Jul 20, 2018 15:22:16 GMT
now look what you did mark ^^^^^^ ,,everyone's doing it !
Jul 20, 2018 16:09:16 GMT
Were you by chance a Ladies Lingerie designer in a previous life?
And you will make Grizz oh so jealous.
Jul 20, 2018 16:27:26 GMT
Hmm less Medusa more Madonna V V
Last Edit: Jul 20, 2018 16:28:16 GMT by wightfug
