Dez
Club RR Member Number: 34
Apr 11, 2015 11:43:24 GMT
yeah, my workshop is slightly overloaded. lots of cheap items for sale, no messing about, i can post them all for between £5-10, please no messing about arguing over a pound, i just want quick simple sales and stuff gone. 1. pair good sierra rear drums, £10. 2.28-29 model A sedan centre roof steel bow. i think 30-31 is the same. £20. 3.drag racing pictoral. SOLD. 4. pop browns hairpin bracket. SOLD. 5. pop browns panhard bracket, axle end, used, £5. 6.vauxhall senator front wing. £10 7. mk1 golf gti 100mm (larger size) output flanges. £15. 8. series land rover/other offroaders retrofit high level axle breather kit, new/unused. £10. 9. dellorto carb choke mechs- for 40s/45s etc. £15. 10. WARN winch plug in remote (no plug) £5. 11. armstrong lever-arm shocks, various types, for rebuild. SOLD. 12. VW variant/ type 3 early front indicators. SOLD. 13. sykes pickavant steering column bearing tool for early mini. new from what i can tell. £15. 14. couple of owners handbooks. SOLD. 15. speedway bearing adapters/backplate spacers. SOLD. 16. american license plate bracket. SOLD. 17. used rear shocks, 58-64 GM fullsize, impala etc. £10. 18. porsche 928 horn button/pad £10. 19. dash mount bias pedal box adjsuter, mk2 escort, etc. £15. 20. early lucas 'batwing' rear light. SOLD.
Last Edit: May 4, 2015 17:45:12 GMT by Dez
Dez
Apr 11, 2015 11:46:02 GMT
21. 58-64 chevy impala gearbox crossmember £10. 22. single scimitar SE6 rear brake drum- larger size. £20 23. chrome lucas rear number plate lights. i have a couple on VGC, £10 each. 24. thermostatic oil cooler take off plate, GM made, for CE20 engine etc. but can be adapter to pretty much any with the right centre screwy bit (no inc.) £20. 25. viva/victor hubcaps. SOLD. 26. in car CD wallet with volkswagens on, £5. 27. small ammo box, £5. 28. old esso lubricants flipchart, £10. 29. eibach camber adjust bolts for mk1/mk2/mk3 type golf/vw front struts. SOLD. 30. cast ally gearknobs/handles. only right for RHD cars obviously. ive got a few, £5 each. 3sold, 7 left. 31. pinto sandwich plate, £10. 32. retro audi mudflaps, near new. SOLD. 33. track rod end, new. £5. 34. mini drive couplings, new. £10. 35. 105e anglia front brake backplates, £15. 36. 105e anglia front/rear drum. £20. 37. pair unkown 19" wires, chevy 4.75" PCD. a couple of broken spokes on each, need sandblasting. SOLD. 38. datsun pickup front grille, £20. 39. '70s french racing bike frame, small size 19.5", 27"/700c wheels, £20. 40. silver top zetec part wiring loom, injectors etc. £5.
Last Edit: Apr 13, 2015 20:25:45 GMT by Dez
Dez
Apr 11, 2015 11:47:23 GMT
41. E83W fordson front drums. have bearings but caps are now gone. £20. 42. ford anglia 105e rear springs, think the other bits are gone now. need a sandblast really. £20. 43. classic mini sykes pickavant clutch/flywheel service kit. SOLD. 44. ford anglia van rim, had a dent thats been hammered out £10. 45. land rover series 2,2a,3 propshafts, theres both front and rear, £20 for both. 46. land rover series 2,2a,3 rear halfshafts, £20 for both. 47. vw beetle inner rear wing repair panel £10. 48. ally steering column trim. SOLD. 49. single/odd side marker, good quality, £5. 50. new old stock tex mirror head, think its 5", £10. 51. '50s f100 seat runners, £15. 52. copy of hot rod magazine. £4. 53. job lot bike mags, bought mostly for bobber content £5. 54. pop umbrella handbrake. SOLD>. 55. ratty old pushbikes. i have half a dozen in various state of disrepair, £15-20 each. 56. vauxhall victor/viva 4x4" pcd 13" wheels, £15 the pair. 57. sit up and beg pop screen £10. 58. cut-out ;60s beetle RHD dash, £20. 59. weber 34ICH carb for rebuild- various forld, land rover, rootes, etc. £20. 60. whiteband tyre, good 5mm+ tread, £15. 61. dixon-bate ball and pin towhitch, all complete but pin siezed, i havent tried to free it. £15. 62. massive old hook-type towhitch. SOLD. 63. assorted VW 4x100 pcd 14" steels, tyres hold air but are probably not legal, £5 each. 2x now sold, 2x left. 64. pair tyres, one sunny one dunlop, both good legal with plenty of tread £15. 65. bmw e36 momo steering wheel boss kit. SOLD. 66. cool old steering wheel, alloy centre steel the rest, needs recovering (was plastic wrapped) thing it said standard avon on it? £20. 67. a pile of checkerplate offcuts. £20. annnd thatll do for now. gone slightly over the 50! stuff can be collected from manningtree nr. colchester, or post is 5-10 quid depends on what it is.
Last Edit: May 4, 2015 17:48:12 GMT by Dez
Apr 11, 2015 17:37:46 GMT
Hi what is the fitting hole thread size & how many you got! ta Gra item 30 gear knob
Last Edit: Apr 11, 2015 17:39:33 GMT by anoldgit
Apr 11, 2015 17:56:29 GMT
darn, if only you were not so far away .
Dez
Apr 11, 2015 18:48:02 GMT
gra-
dimensions 125mm tall, 50mm diameter at largest, hole 21mm most of the way up(so will fit a standard 7/8" bmx handlebar with a quick clean out), but at the top there is a section 12mm deep with a 12mm hole for securing (bolting down) (see pics). roughcast, have had flashing removed. LEFT HAND HANDLES ONLY, so fine for a normal gearshift or central handbrake in a RHD car.
i think ive got somewhere between half a dozen and a dozen, i'll take a look on monday.
dave-
hilarious!
gavs1
Apr 11, 2015 18:56:13 GMT
Side marker light, and bat wing light. Plz.
Dez
Apr 11, 2015 18:59:02 GMT
think the batwing is gone pending payment, still have the marker though.
actually, ive half a mind ive got two batwings, or at least something similar, i'll have a look on monday.
Last Edit: Apr 11, 2015 18:59:32 GMT by Dez
arge
Apr 11, 2015 19:01:25 GMT
I will have the hubcaps please.
Please pm a price and details including postage please!
gavs1
Apr 11, 2015 19:07:10 GMT
think the batwing is gone pending payment, still have the marker though. actually, ive half a mind ive got two batwings, or at least something similar, i'll have a look on monday. Ok that's great.
Rich
Club RR Member Number: 160
over 50 items all under £20 each.Rich
@foxmcintyre
Club Retro Rides Member 160
Apr 11, 2015 20:31:01 GMT
That sankey/hoop hitch would be so useful on the disco but postage would be killer on that no doubt.. Let me know if you reckon you can post it Dez..
Dez
Apr 11, 2015 20:32:29 GMT
i think itll go for a tenner rich, don't think its over 20kg.
Rich
@foxmcintyre
Apr 11, 2015 20:36:44 GMT
i think itll go for a tenner rich, don't think its over 20kg. Yea? Let me know and send me your paypal and I'll fire the wedge over
Dez
Apr 11, 2015 20:41:45 GMT
just had a look and i can do 25kg for a tenner as long as it aint worth owt, so i'll PM you now. you do mean the great big hook shaped one, yeah?
Rich
@foxmcintyre
Apr 11, 2015 20:48:09 GMT
just had a look and i can do 25kg for a tenner as long as it aint worth owt, so i'll PM you now. you do mean the great big hook shaped one, yeah? That's the one. Seeing as I'll be using the disco to help move a tonne of 30's and 40's lorries and trailers in June and before a hook hitch will be more useful than a pin (too small for most of our trailers) or ball hitch.
Apr 11, 2015 21:41:56 GMT
I'yll take the Audi mudflats posted Dez
Dez
yep, drop me a PM for payment details.
1mzmk1
I'll take no.43 the mini clutch tools please if still available. I'll PM you now...
Seth
Apr 12, 2015 21:20:19 GMT
These for me please if they are still available and you can hang on for some sort of pony express arrangement?
Do the tyres hold air? Not expecting them to be legal just wondering if they'd roll....
Ryannn
Apr 12, 2015 21:49:28 GMT
Dez, please can I have number 14? The two mini books. I'll PM you now, thanks
