Nice. Hope you like it.
If you don't, and decide to sell/ swop- please give me a shout. I'd quite like a Polo engined version. Ta
dubscum
thats what i do
does it wheelie Phil ?
whip it, into shape ........ go forward
v8ian
Just a thought . . . . .
Unfortunately not. However, it is somewhat sedate in its acceleration. True to form. Phil
dubscum
thats what i do
Just a thought . . . . . whoa!!!!!!!!!!!!
dubscum
thats what i do
Nov 22, 2015 10:36:10 GMT
my wife uses the trampant for running about in, since using it the boot hinges have broke, and the passenger window has broke, i gave it a service and bought some Hungarian reproduction boot hinges. They worse thing I've ever seen haha then spent a few hours modding them juts so they fitted. I struggled more with finding the glass, i have a friend who works in germany during the week so he is trying to find me one, So ti keep the water out i made a perspex one i did a trial fit with the banded steels, they rubbed, so i brought e-bay's finest 5mm spacers they still rub .... so i cut the springs to make me feel better I'm a bit gutted the banded steels don't fit as thats the look i wanted . I don't like the standard wheels and 2 of them are close to the limit, then i remembered i had this swapped. proving everything looks better with banded steels on end result for the trabby I don't like it, front looks better a bit lower, but the wheels are too big, don't suit it, the rears are reversed camber and rub the arch. i need to chop the rear springs and find some low ET wide, 13" 4x100 different wheels cheap ,,,,,,
Nov 22, 2015 11:54:27 GMT
Needs to be lower. An air set up would be awsome on it!!
dubscum
thats what i do
Nov 22, 2015 15:06:09 GMT
I know it needs to be lower. I'm looking at some alleycats next week. Air would be ace but it's a budget build so it more chopped springs then air struts
Nov 22, 2015 17:42:52 GMT
Probably better to adapt some cheap coilovers than cutting the springs.
Nov 22, 2015 21:32:47 GMT
Looking good. Depending where you are I have a spare door glass and tonnes of other parts for a kombi I'm in Somerset though
it's not the holes that are rotten it's the metal around them
1975 trabant 601s deluxe
1987 trabant 601 Kombi
1996 fiat cinquecento 1.4 16v
Nov 22, 2015 22:21:50 GMT
What you need for the back end is some camber correctors. You can get them from LDM Tuninng or Trabantwelt. Or I have seen some technical diagrams on the net. so if you know someone with a lathe you could get some made.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
Nov 22, 2015 23:17:31 GMT
there was one for sale last week gumtreederry for £650 ono same colour
dubscum
thats what i do
Nov 23, 2015 20:34:31 GMT
Looking good. Depending where you are I have a spare door glass and tonnes of other parts for a kombi I'm in Somerset though Next time we holiday in Cornwall I might pop in ?
dubscum
thats what i do
Nov 23, 2015 20:37:08 GMT
there was one for sale last week gumtreederry for £650 ono same colour We paid £700 but it's had a new floor and sills, inner arches and all new brake lines etc.
dubscum
thats what i do
Nov 23, 2015 20:38:47 GMT
Probably better to adapt some cheap coilovers than cutting the springs. I've seen some polo 80mm lowering springs for about £60 on eBay. I might try them
dubscum
thats what i do
Nov 23, 2015 20:39:49 GMT
What you need for the back end is some camber correctors. You can get them from LDM Tuninng or Trabantwelt. Or I have seen some technical diagrams on the net. so if you know someone with a lathe you could get some made. Very much need these, cheers pal!!! Do these sit under the springs or extend the arm?
Nov 23, 2015 21:01:35 GMT
I broke a 1989 a while ago and still have nearly everything most is being kept as spares for my saloon. So yep feel free to pop in whenever.
Those camber adjusters iirc goes between the body and the arm and are available for different cambers ldm tuning sell them
dubscum
thats what i do
Nov 25, 2015 20:49:33 GMT
I'll order some camber correcters. Would you consider courier the window if I pay and arrange a courier ? Can't beat a clear work space lol Going back to black and back to steels
dubscum
thats what i do
Thre is not enough day light hours in the day. Drives better on the steels. Had it tracked too
