Hi, I'm looking for a set of uprated lowering front springs (Ford size?) .
The one's I'm using now are Capri Mk2 2.0, 190lb 2" drop (8" free length) which fit fine but are soft. I think Escort are same size.
Wanted : springs for Capri Mk2 2.0 (or Escort?), 300lb (or something close, 275lb ?), 2" drop.
measurements : diameter 5.25" outside diameter (inside diameter 4.5" ), spring free length about 8"
More info : retrorides.proboards.com/thread/177578/hillman-hunter-lowered-uprated-spring?page=1&scrollTo=2065094
This is a "make-it-fit" type project, so something close might work.
Cheap is good, either used or if you know anywhere with these in their clearance sale
Thanks
Thanks
