79cord
Do Mercedes Mono-wipers park outside their normal sweep? Tempted to buy one for a custom detail but want to hide them, some cars pull their wipers down past their normal swept area ( and fully off windscreen) to hide lower in cowl when parked out of use. I want this but wasn't sure if Mercedes had the feature other than normal parking at bottom of travel. Might team monowiper with another motor if it does not.
hario
S202 C300STD
Mar 18, 2015 13:35:32 GMT
Nope they don't, just controlled with end of travel limit switches.
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
bortaf
Mar 19, 2015 12:02:09 GMT
Fixed one a few weeks back that was parking up the screen (05 plate), they use copper tracks that hold a constant live till the end of the tracks to park it, easy to fix but not to easy to extend/play with IMHO
R.I.P photobucket
THE_Liam
Yorkshire and The Humber
If at first you don't succeed... HAMMERS.
Mar 19, 2015 12:47:14 GMT
They park at the bottom on the drivers side usually, but they don't conceal - the linkage is very complex due to it being telescopic in movement, have a look for a youtube video and you'll see what I mean.
Maybe a Citroen BX wiper instead?
Mar 19, 2015 13:43:59 GMT
Can't you achieve the hidden look by modifying the cowl or bonnet edge a bit, the effort involved might be comparable to re-engineering the car to accept a wiper from another model.
VIP
Mar 19, 2015 15:37:13 GMT
LS400 wiper systems park. You could just adapt the linkage to make it sweep the full screen.
